- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Hello all,
I am using MAX10 FPGA and want to measure the temperature via built-in temperature sensor. I have some LEDs on my PCB and I am controlling LEDs through PWM engine. I am measuring PCB temperature also. For this I am using ADC ip in quartus II and I am able to read Temperature sensor values. All is working but now I need to control PCB temperature from 30 °C to 50 °C. When PCB temperature reaches to 30 °C LEDs should de-rate its brightness to 10 % (90% ON) and when 35 °C LEDs should decrease brightness to 20% (80% ON) and so on and vice versa. So for this I get to know that I need to apply Hysteresis of 5 °C in my VHDL coding. Please help me to make hysteresis technique in my code. Thanks. And don't hesitate to ask questions. Regards UsmanLink copiado
4 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi.
You may introduce signal called 'direction' for storage where temprature moves to. the you can create several conditions, for example cond1 := (direction = down) and (temp < 30) cond2 := (direction = up) and (temp > 35) then you can trigger events based upon conditions. Hopy you'll catch an idea.- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Alex,
Thanks for your reply. Sorry, I don't understand the 'direction' signal. Temperature values are already going to temp signal so what is the purpose of 'direction' signal. And I got the idea when I need to trigger the events based upon condition. But dont understand the condition. Can you please elaborate. Thanks for your time.- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Oh. it's easy.
for example, let's give name for expression (new_temperature minus old_temprature) dT, then we need to know the sign of dT. so if temprature has 16 bit, you should extend the dT by 1 bit, so dT is 17 bit if it is negative so you have direction = down, otherwise direction = up if dT /= 0, in other case it is untouched. but you can introduce 'temp_change' like condition3 and asssign it like condtion3 := (dT /= 0); So you problem may be clear if you'll write the graph for yourself on paper and determine several condition from your hysteris painted on peace of paper. Finally, if condition3 = false so temprature doesn't change. then you can use outside you hysteresis condition3 = true and condition1 = true - it means temparure move towards small values, condition3 = true and condition2 = true - it means temprature move towards big values inside you hysteresis you can make yourself.- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Usman,
To introduce some hysteresis into your calculation you need to store one (or more) calculated temperature values and use the stored value(s) when calculating your new temperature. You'll need some time interval appropriate to your system - this might be 1ms, 1s, 1 minute or 1 hour (or something else). At each time interval you calculate a new temperature based on your newly read temperature AND your stored value(s). You will need to 'weight' each value used for the calculation appropriately - typically older values contribute less to the newly calculated value. This will introduce hysteresis into your temperature calculation. Cheers, Alex
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
