17240 Diskussionen
I can't Install USB blaster.
BRRRRT
Einsteiger
1.155Aufrufe
I install Quartus Prime Lite 20.1.1. it successfully installed but usb blaster driver isn't.
I try to install manually but I failed every time. I try to find new driver, but it seems all driver download page is dead.
dose anyone have new driver file?
1 Lösung
NurAiman_M_Intel
Mitarbeiter
1.138Aufrufe
Thank you for contacting Intel community.
That might be due to issue with USB Blaster. Kindly follow the workaround in KDB below (it is also applicable for USB Blaster):
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2021/why-does-the-intel--fpga-download-cable-ii-driver-installation-f.html
Aiman
Lösung in ursprünglichem Beitrag anzeigen
4 Antworten
NurAiman_M_Intel
Mitarbeiter
1.139Aufrufe
Aiman
vg2
Einsteiger
1.100Aufrufe
Can you provide a similar link for USB-Blaster? It has the same expiration issue.
Thank you,
VG2
BRRRRT
Einsteiger
1.096Aufrufe
vg2
Einsteiger
1.060Aufrufe
Thanks, BRRRRT,
I will try it.
After I posted my question I was able to install the driver in  a special boot mode without signature check:
https://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/
BR,
VG
Antworten
