17238 Discussions
I can't Install USB blaster.
BRRRRT
I install Quartus Prime Lite 20.1.1. it successfully installed but usb blaster driver isn't.
I try to install manually but I failed every time. I try to find new driver, but it seems all driver download page is dead.
dose anyone have new driver file?
NurAiman_M_Intel
Thank you for contacting Intel community.
That might be due to issue with USB Blaster. Kindly follow the workaround in KDB below (it is also applicable for USB Blaster):
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2021/why-does-the-intel--fpga-download-cable-ii-driver-installation-f.html
Aiman
NurAiman_M_Intel
Aiman
vg2
Can you provide a similar link for USB-Blaster? It has the same expiration issue.
Thank you,
VG2
vg2
Thanks, BRRRRT,
I will try it.
After I posted my question I was able to install the driver in  a special boot mode without signature check:
https://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/
BR,
VG
