17261 Discussions
I have a DSPBA block that is functionally working but the timing in the overall system needs to be improved. DSPBA is giving me an error that doesn't make sense.
MSchn21
I want to do this by adding an intentional pipe stage at a key point in the block design. I should be able to do this by making a dummy subsystem that only has ChannelIn and ChannelOut components. When I stick this dummy subsystem in the top level system, I get an incomprehensible error:  Error reported by S-function 'mip_control' in '<myblockname>': exception "invalid vector<T> subscript" in CModelGenPass.buildModel() for block.....
As I mentioned, the error wasn't helpful and what I was doing shouldn't have been a problem I think.Here is a picture of the subsystem
KhaiChein_Y_Intel
Hi MSchn21,
I could not see the picture of the subsystem. Could you reattach ? Could you provide a test case to reproduce the error?
MSchn21
Hi YY. Attached is the detailed info. I don’t want this posted to the forum per my company’s policy. Myron
KhaiChein_Y_Intel
Hi Myron,
I could not find the attachment in this thread. Let me send a private message to you and you could attach in the message.
YY
