17268 Discussions
I'm having trouble beginning any simulation in Quartus Prime 18.1
ERagu
I've recently downloaded Quartus Prime Pro 18.1. I'm trying to get even a basic simulation started so I can work from there. I followed this guide here:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_gs_msa_qii.pdf
And downloaded the example file, but I think this guide was written for a different version. For example, there is no Tools ➤ Options ➤ EDA Tool Options in my Quartus Prime. My Assignments ➤ Settings ➤ EDA Tool Settings ➤ Simulation looks quite different, and doesn't have the NativeLink section, so I can't start any simulation.
I can go to Tools ➤ Generate Simulator Setup Script for IP, but when I click it, I get this error message:
Error: 2019.01.17.18:10:20 Error: Device family cyclonev is not supported by ::quartus::sim_lib_info.
Are there any good step by step instructions on how to get started with the simulations?
CalvinJoaz_P_Intel
Hi Eric,
Good day.
Quartus Pro doesn't support the Native Links options but only in Quartus Standard.
Refer the previous thread with similar issue.
https://forums.intel.com/s/question/0D50P00003yyTTESA2/quartus-prime-pro-161-eda-tool-options-not-showing-up-in-tools-options
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Thank you.
ERagu
Hi Calvin,
Do I need to install the Cyclone V board?
ERagu
Hi Calvin,
CalvinJoaz_P_Intel
Hi Eric,
Which device you're using? If you're using Quartus Pro, It doesn't support Cyclone V devices.
Refer link below.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/po/ss-quartus-comparison.pdf
Thank you.
ERagu
The device I'm compiling for is a Cyclone 10 GX, so according to that it should work. I believe I'm getting the error because the simulator setup script is also trying to set up for the Cyclone V. Is there any way of altering that?
CalvinJoaz_P_Intel
Hi Eric, Apologize for delayed response. Kindly refer link below. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/ug_cyclone10_xcvr_phy.pdf Thank you.
