I refer to Avalon MM templates to write a code for master read
But I only get the last 64 data when I using master read For example : I want to my output are 0~127 , but I only get 65~127 is some signals I forgot to setup ? thanks
`timescale 1ns/1ns
module master (
clk,
reset,
master_address,
master_byteenable,
master_waitrequest,
go,
/////////////////write///////////////////////
master_write,
master_writedata,
source_data,
write_addr,
write_en,
master_readdata,
master_readdatavalid,
to_addr_readdata,
read_en,
read_addr,
master_read,
index,
// for_read_en
fifo_ren,
fifo_wen,
fifo_clk,
for_fifo
input clk;
input reset;
input index;
output fifo_wen;
output reg fifo_ren;
output fifo_clk;
// DDR2 master port
input for_fifo;
output reg master_address;
output master_byteenable;
input master_waitrequest;
output go;
input write_en;
output master_write;
output master_writedata,to_addr_readdata;
input source_data;
input write_addr;
input master_readdata;
input master_readdatavalid;
output reg master_read;
input read_en;
input read_addr;
reg to_addr_readdata;
wire read_go,write_go;
assign master_byteenable = -1;
assign master_writedata = source_data;
assign go = master_waitrequest;
assign fifo_clk_1 = ( clk & (!master_waitrequest) & for_fifo);
assign fifo_clk = (fifo_clk_1 & master_read);
assign fifo_wen = (read_en && (!master_waitrequest));
always @(posedge clk or negedge reset)
begin
if (!reset)
begin
to_addr_readdata <=# 1 0;
master_address <=# 1 0;
master_read <=# 1 0;
end
else
begin
to_addr_readdata <=# 1 master_readdata;
master_address <=# 1 read_addr;
master_read <=# 1 read_en;
end
end
endmodule
