- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
:p Hi,
everyone. I really need some hints.No matter how hard I try,I can never execute the "Creating Multiporcessor Nios II Systems " sucessfully on the hardware. I have tried the following ways: 1.Following the tuturial,I use the shell to generate the files and then import them to the SBT Eclipse(10.0).After build it ,I can not find "run on hardware" on the "run" Tab; 2.In Eclipse,I create a new project and directly copy the application source code to the project. I choose "microC/os" and"niche" for the BSP.But when I build it ,it is said that many heads files can not be found.For example ,the file "altera_avalon_pio_regs.h"; 3.Then I try to use IDE(9.1) because I have successfully execute several programs in the IDE before. I create a project and copy the source file into it.Then when I complie it ,the error happens: "ERROR - Nios II system libraries in the IDE development flow do not support an external interrupt controller port on the Nios II. Use the Nios II software build tools development flow instead." Then I download the SP2 for both QuartusII and EDS and try it again.But the error is still there. I have spent a lot of time on it but still did not figure it out .Can anyone give me any kind of clue and hint? I will really appreciate that .Thanks !!!:DLink kopiert
5 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
the clue is there, isn't it? you can't use Nios IDE because it will not be supported going forward. you must use the Nios II Software Build Tools to use that particular component
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thank you for your reply.But you can check the SP2.It is said that the SP2 adds the support for the interrupt controller. I tried the eclipse,but it seemed that the application always can not find the necessay files in the BSP.I do not know why...- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
:D :D :D very complicated indeed, never got it to run , have not tried it for a while :mad:
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
It is not very complicated.
But my problem is that ,in eclipse, it seems that I can not create the necessary BSP well compared with in the IDE.But in IDE,it seems that the interrupt controller is not supported. Does anyone successfully execute this tutorial?- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi,I think finally I figure it out.When I use eclipse 9.1 ,I could not find "Nios II application and BSP from template".So I give up 9.1 and use 10.0 instead.However, the files in the tuturial seems to be 9.1 version and when I open the BSP editor in 10.0,in the Drivers Tab,nearly all the drivers have not been found.
So I just uninstall all the Altera Sofeware and delect the remaining files,and then I download and install version 9.1 again.Now I can build successfully!
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
