17267 Discussions
I would like to install quartus prime lite programmer on window 32bits
POliv9
I download the following tools: (LITE version)
QuartusProgrammerSetup-16.1.0.196-windows32.exe
QuartusProgrammerSetup-18.1.0.625-windows32.exe
In order to install on the 32bits window PC.
When I launch the command line quartus_pgmw.exe , I get a popup than said me this command is not a 32bits command.
What i need to do in order to run this command on a 32 bits PC
CalvinJoaz_P_Intel
Hi Peley,
Starting with Quartus 14.0, Intel FPGA software only supports 64 bit versions unless 32-bit for standalone programmer is only supported in standard edition.
Kindly check the link below.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/os-support.html?_ga=2.244220165.1486944517.1545179103-1133098667.1531296192&elq_cid=4305564&erpm_id=6981650
Thank you.
