17257 ディスカッション
IHEX file and Convert Programiing
名誉コントリビューター II
1,410件の閲覧回数
I am using Cyclone III Quartus II 9.0 SP 2, windows XP.
I have am trying to generate and download .pof file to a flash but it didn’t seem to work.
Here is what I did:
1. I created a intel hex format file (for application fw) in the script below:
…# define project name, path name, and file name
PRJNAME=Next
NIOSDIR=$PRJNAME"_NiosII"
BSPDIR=$PRJNAME"_Bsp"
APPDIR=$PRJNAME"_App"
SOPCFILE=$PRJNAME"_NiosII_System.sopc"
SOFFILE=$PRJNAME"_NiosII.sof"
ELFFILE=$PRJNAME".elf"
# enter app directory
if [ -f ./$APPDIR/Makefile ]
then
cd $APPDIR
else
exit
fi
# clean old object files (currently disabled)# make clean
# compile per Makefile
make
# Relocate the firmware version section
nios2-elf-objcopy --change-section-address .fw_version=0x290000 next.elf next.elf
# Create the S-record from the the .elf file
nios2-elf-objcopy -O srec next.elf next.srec
# Create the ihex from the the .elf file
nios2-elf-objcopy -O ihex next.elf next.hex
# clear USB Blaster
jtagconfig
jtagconfig
I need to generate both srec file and ihex file, so I am doing it consequentially.
Ihex file seems to be successfully generated
I am using .hex file generated above and .sof file to generate POF file.
POF file seems to be generated successfully
Program was downloaded successfully.
All the step above shows that all set up was successful
However, the firmware doesn’t work so we did several testing.
Our findings:
1. .pof file is downloaded properly
2. configuration (.sof) seems failed to load properly.
3. Confdone signal is always low.
We need your help to solve this problem. We believe this is a set up issue
The reason is:
1. We are able to download firmware to flash via JTAG,
using the same .sof file
and .srec file
So maybe the ihex file is generated wrongly or convert programming files is not set up properly.
Let me know your comment
0 件の賞賛
0 返答(返信)
返信
