I am working on a design using an Agilex F-series part (AGFB014R24B2E3V) and am having issues with tri-stated outputs. The RTL in question is:
assign TRIG[0] = (lb_enable_dd) ? clk_fast : 1'bz;
When I test my board, I found it to be inverted. If I set lb_enable_dd high, it was hi-z, low gave me clk_fast on my TRIG[0] output. When I opened the Technology Map View (post-fit) I noticed the IO_OBUF primitive had a inverter on the OE input that didn't seem to be compensated for in compile.
Things I have tried:
- Tested both 21.2 and 21.3 versions of the tools.
- Switching to a non-tristating output. This works as expected, no polarity issues.
assign TRIG[0] = (lb_enable_dd) ? clk_fast : 1'b0;
- Tried generating the buffer using the GPIO Intel FPGA IP core from the library.
trig_out trig_out (
.din ({lb_rxclk_det[0], clk_fast, lb_enable_dd, clk_fast}),
.oe ({4{lb_enable_dd}}),
.pad_out (TRIG[3:0])
Same inverter present on the IO_OBUF. Even when I open the datasheet for that IP core it says OE should be active high.
Thoughts?
Tri-state buffer can be either active high or active low. There are many types of it you can refer here. What I can guess is that IO_OBUF is most likely an active low tri-state buffer.
Moreover, --OE is active high-- you highlighted in manual don't very related to IO_OBUF mentioned above. That is for Data Interface Signals of gpio ip.
Sheng
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
That doesn't change the fact that when I implement an active-high tri-state buffer (either with RTL or instantiating a GPIO IP block), the tools put in the IO_OBUF and the polarity of the OE is active-low, but that doesn't seem to be compensated for.
The behavior of my hardware is the opposite of what I have coded for the design and when I drive 0 instead of hi-Z in the "disabled" state the polarity is now correct. I have never actually instantiated an IO_OBUF, that is just what the tools used during synthesis but it seems like they are not compensating for the active-low OE of that primitive.
So...
lb_enable_dd = 0, TRIG[0] = clk_fast (observed on the HW, which is wrong, it should be hi-Z)
lb_enable_dd = 1, TRIG[0] = hi-Z (observed on the HW, which is wrong, it should be clk_fast)
lb_enable_dd = 0, TRIG[0] = 0 (observed on the HW, which is correct)
lb_enable_dd = 1, TRIG[0] = clk_fast (observed on the HW, which is correct)
Rob
Hi Rob,
In order to be in tri-state mode, you have to drive "hi-Z" instead of "0". Otherwise, it will be switched to a non-tristating output as you say before if you drive "0". Thus, driving "hi-Z" or "0" will result in two different modes.
In tri-state mode, IO_OBUF primitive comes originally with active-low OE internal settings. That is the primary internal logic function of IO_OBUF primitive which you cannot simply change it.
Btw, you can refer to here https://en.wikipedia.org/wiki/Three-state_logic as well for Three-state logic. (Many devices are controlled by an active-low input called OE (Output Enable) which dictates whether the outputs should be held in a high-impedance state or drive their respective loads (to either 0- or 1-level).)
Sheng
Yes, I understand driving 0 will instantiate a different buffer. I am using that "version" to show that my logic is sound.
Let me put it more simply. If my RTL contains this line in the top level, and TRIG[0] is defined as an output pin on the top-level design.
And lb_enable_dd is "1", what would you expect on the output pin TRIG[0]? I think it should be "clk_fast".
And if lb_enable_dd is "0", I would expect Hi-Z? Does that sound correct?
If so, there is a problem in the way Quartus is synthesizing this statement.
I believe you that IO_OBUF has an active low OE input, I see that in the tech view. However, why is there no inverter instantiated by the tools before the OE# input to match the logic defined in the RTL. This is the issue. What I am coding is not what I am getting, and I have confirmed this on the hardware as well.
Hi Rob,
Can you provide a sample project with the problem for better viewing?
Sheng
Hi Rob,
I further think about the problem you mentioned and found out should be no problem with both IO_OBUF primitive and RTL.
IO_OBUF primitive is designed to be active low OE means you have to use '0' instead of '1' to enable output in order to enable the clock.
So when using assign TRIG[0] = (lb_enable_dd) ? clk_fast : 1'bz;, an inverter is automatically added to make the RTL matches the IO_OBUF primitive design setting. If change to assign TRIG[0] = (lb_enable_dd) ? 1'bz : clk_fast;, I guess the inverter will most likely disappear. The problem is IO_OBUF OE part there will change based on which RTL you are using to make sure '0' is used to enable output at last.
If you still insist to use '1' for triggering the clock, I think you have to additionally add a not gate or inverter in front of active low OE manually by yourself. O_OBUF primitive setting will not do that for you.
Sheng
"So when using assign TRIG[0] = (lb_enable_dd) ? clk_fast : 1'bz;, an inverter is automatically added to make the RTL matches the IO_OBUF primitive"
You seem to be missing the point. The tools ARE NOT automatically adding this inverter, that is my whole issue!!!!!
Hi Rob,
What I mean is assign TRIG[0] = (lb_enable_dd) ? clk_fast : 1'bz; represents the whole IO_OBUF primitive. For that assign, obviously '1' is needed to trigger the clk_fast. However, IO_OBUF primitive needs to function as active low OE means lb_enable_dd needs to be '0' at any point. For that assign, if lb_enable_dd is '0' 1'bz will be selected right? If like that IO_OBUF is not active low OE anymore. So an inverter is automatically added to compensate for that (first pic you share).
In order to use '1' for clk_fast triggering, you have to manually add a not gate or inverter.
Sheng
Hi Rob,
Do you have any further update or Should I consider that case to be closed?
Sheng
The problem still persists. The Quartus synthesis is failing to add the required inverter in front of the IO_OBUF to match the logic in my RTL.
Inverting it on my end changes my intended logic (and would still likely be wrong on my end).
The issue appears to be in the tools, not my RTL, so I can't see a way that I can fix this on my end.
Hi Rob,
Can you provide a sample file which duplicates the issue for better viewing? If that's a bug, I can reflect this to internal team with the reference file.
Sheng
Sure. However, can you please be more specific as to which file(s) you want to look at? I want to make sure I provide adequate information to look at.
Or do you mean create a very small project that demonstrates the error? I can do that too, will just take a bit more time.
I made a very simple new project. The same device (AGFB014R24B2E3V). This is the RTL.
module tri_test (
input logic clk1,
input logic clk2,
input logic en1,
input logic en2,
output logic out1,
output logic out2
assign out1 = (en1) ? clk1 : 1'bz;
assign out2 = (en2) ? clk2 : 1'b0;
endmodule
You can see that out1 "should" be clk1 if en1 is high, and Hi-Z if en1 is low. You can also see the post-fit Technology Map Viewer shows the polarity implemented is wrong (there is no inverter added to compensate for the active-low OE on the IO_OBUF primitive).
The out2 circuit is the same logic, but without the tri-state (it just outputs 0 if en2 is low).
The whole project folder is now attached.
Hi Rob,
You're absolutely right. Sorry for the confusion before. The post-fit Technology Map Viewer result is totally opposite of the RTL viewer and simulation. I noticed this problem still persists on version 21.3 and above.
I also found out a previous similar issue from KDB here. By right, the problem should be fixed beginning with version 21.3 but looks like it wasn't being solved thoroughly.
At the mean time, I think you can invert the output enable signal in your RTL by using assign out1 = (!en1) ? clk1 : 1'bz;. By doing this, can temporarily get the correct output and post-fit Technology Map Viewer.
I'll reflect this bug to internal team for further investigation.
Sheng
I am hesitant to simply invert the control to "work around" this bug since all it will take is a newer version of the tools (with the fix in place) and suddenly the polarity of the control signal will be wrong again (at a system level).
If I am the one working on this new version that would be fine, but if it is someone else, they won't necessarily have the historical information to know what is happening.
At this point, I would just like to be kept in the loop on the fixes being made, and what release of the tools will contain the fix. Also, if there is a pre-release patch that becomes available I would like to know about it.
Is there a way to get on a notification list or something?
Hi Rob,
The internal team feedback is the problem will be planned in version 22.3. You may keep tracking the progress from here https://hsdes.intel.com/appstore/article/#/15010826170
Sheng
Hi Sheng,
Can you tell me what the progress is on this issue? The link you provided is no longer valid. As per your last email, the fix was planned for Q22.3 but I can still see incorrect behavior in 22.4.0 Pro Edition. If there is a workaround or a patch, that would be great as I am avoiding upgrading Quartus versions due to other unrelated support issues.
Nadine
Sorry for delay reply,
Engineering had confirmed that the behaviour is correct check below:
The bubble is to indicate the inversion to compensate for the active low oe port of the obuf. So, what you see in the tech map view is actually correct.
I see the RPI is not set for out1 to invert the core signal to OE. However, we use RBC to set the programmable invert for the OE inside fm_gpio to compensate for OE being active low. So, it should work fine.
And we also have BCM simulation of a design similar to the sample test design and it is working fine.
set up running BCM simulation for design tri_test.zip.
Looking at the result, the behaviour of the OE is expected.
The RTL is:
The simulation waveform is:
You can see when en1 is low, out1 is Z regardless of clk1.
You can also see when en1 is high, out1 follows clk1.
in initial post of this thread, it's stated that Quartus is implementing wrong en signal polarity for tri-stated outputs. In following discussion, actual device behaviour is never mentioned, instead only wrong technology map is shown.
I see now that all Quartus versions (Std and Pro), up to most recent have wrong polarity of en port in technology map viewer, as seen below for Quartus Std. 24.1
module tri_test0 (
input logic in1,
input logic en1,
output logic out1
assign out1 = (en1) ? in1 : 1'bz;
endmodule
RTL Viewer
Implemented hardware is however behaving according to RTL description, the fault is only in technology map viewer.
Inverting en1 in code flips all polarities, RTL map and hardware behaviour are still correct, technology map is wrong.
module tri_test0 (
input logic in1,
input logic n_en1,
output logic out1
assign out1 = (!n_en1) ? in1 : 1'bz;
endmodule
I have no Agilex 7 board at hand to check if it shows wrong hardware behaviour as claimed in post #1, either with previous or recent Quartus Pro versions.
I feel that Intel should clarify if there actually has been wrong hardware behaviour of tri-state output with Agilex 7 or other devices in any Quartus version. And also if obviously wrong polarity display in technology map viewer is planned to be fixed.
Frank
The RTL is:
