17253 Discussions
IO constraints for buses routed through FPGA
I hope this is the right place for this question...
I have the following situation...
* multiple SPI buses connected to my FPGA (connecting SPI slaves to FPGA)
* a DSP as SPI master; handles SPI timing
* FPGA behaves as a MUX for the SPI interfaces; purely combinatorial
My question is how should I constraint the SPI interfaces so that the timing at the output of the DSP (correct SPI timing) is kept at the output of the FPGA after routing?
I hope you can easily understand what I meant... Thanks in advance!
For a pure combinational design, only the propagation delay matters, but for the overall operation, a sum of FPGA and slave delays (particularly for the most critical CLK to MISO delay) counts.
What you said makes sense if the delays of the FPGA are insignificant compared to the MOSI/SCK relation. My problem is I can't (don't know how to) trace the delays through the FPGA and I don't just want to assume they will be less than 1 ns... A constraint would spare me of these assumptions...
They are surely a lot more than 1 ns. You can expect around 5 ns for each direction. This are mainly I/O delays that aren't affected by the fitter, so you will hardly achieve a considerably lower value.
However, I didn't suggest to make no constraints. I mentioned, that only tpd constraints are applicable. You have to find out, if they are helpful somehow.
Personally, I would start to check the delays reported by the timing analyzer without any constraints.
That's the way I wanted to avoid :cry:
I have to analyze 6 interfaces (MUX6:1)... probably every P&R run...
what kind of constraints can I actually make? I use no clocks, no registers in the path... TimeQuest is not really useful in this situation...
Thanks for the help so far...
As already mentioned, you would want to specify maximum tpd constraints.
P.S.: (From Rysc's TimeQuest User Guide)
--- Quote Start ---
Combinatorial Paths through Device:
set_max_delay -from [get_ports {<input>} -to [get_ports {<output>}] <Tpd_Requirement>
--- Quote End ---
Thanks, this helped... I had no idea about the existence of this manual, it's awesome :) Thanks!
:cry: unfortunately my problem was not so easily solved...
My FPGA is a Cyclone III.
I tried to constrain the delays between some ranges but it's impossible to match constraints for both slow and fast devices :-( in slow devices typical delay is ~14 ns, I tried to set min 14, max 15 to ensure approx the same delay for all bus signals but than it fails with the fast device that can at most delay ~6 ns...
I don't care how much delay I have, I just want to keep the relation between signals the same and for this only setting maximum delay is not enough :cry:
I noticed in TimeQuest that the delays are though similar for all signals for fast and slow devices (+- 200 ps), I could live with this but I need an automated way of checking this...
I don't understand why you apparently need a minimum tpd constraint? What's the problem when allowing a delay of 6 to 16 ns (if these are the tpd numbers achieved with various devices you want to use for your design)?
--- Quote Start ---
--- Quote End ---
because I am afraid that delays for individual lines of the bus will be different with 0-10 ns...
with a tpd in range 6-10 I ensure that the signals will have a timing variation at the output of the FPGA of maximum 4 ns... that's how I understand it...
O.K., I can understand why. I fear, Timequest isn't prepared for this.
If the logic is simple and not involving a different number of logic cells for individual pathes, the skew can be expected rather small (< 1 ns). If you are using a robust spi timing, there won't be a problem. The most critical parameter would be the SCK to MISO round trip delay.
so since no automated check is possible, with every major change in the source code I should have a look if path delays for the SPI buses are similar... not what I was hoping for...
thanks for the answers, they really helped!
this post helped me alot !!
cheers
