17267 Discussions
Identifier "UNSIGNED" is not directly visible
i have used the following libaries
LIBRARY IEEE;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
USE ieee.numeric_std.all;
still the error in modelsim shows :
** Error: G:/vhdl code/vhdl code/dwt_main.vhd(30): (vcom-1078) Identifier "UNSIGNED" is not directly visible.
Potentially visible declarations are:
ieee.NUMERIC_STD.UNSIGNED (subtype declaration)
ieee.std_logic_arith.UNSIGNED (type declaration)
** Error: G:/vhdl code/vhdl code/dwt_main.vhd(31): (vcom-1078) Identifier "SIGNED" is not directly visible.
ieee.NUMERIC_STD.SIGNED (subtype declaration)
ieee.std_logic_arith.SIGNED (type declaration)
how to solve it
Curious, what did you write for dwt_main.vhd line 30 and 31?
line 30 TYPE buf_ary IS ARRAY(NATURAL RANGE <>) OF UNSIGNED(7 DOWNTO 0);
line 31 TYPE buf_ary_d IS ARRAY (NATURAL RANGE <>) OF SIGNED(7 DOWNTO 0);
Try leaving out:
It is a deprecated library, you will find everything you need in:
i have already included these libraries above
LIBRARY IEEE;
Try just the following:
library ieee ;
use ieee.std_logic_1164.all ;
use iee.numeric_std.all;
yes it worked ....for the time being that error got solved.....thanks
The error is caused by numeric_std and std_logic_arith both declaring the unsigned and signed types, meaning you need to specifically state which one to use:
eg.
signal a : numeric_std.unsigned;
signal b : std_logic_arith.unsigned;
The problem is they are not the same type, and VHDL rules mean that two types with the same name in the same namespace become invisible.
std_logic_arith is not a standard VHDL library - and so should not be used.
