17261 Discussions
Modelsim SE code coverage error
Hi all.
I use modelsim SE 10.4c (not Altera edition).
I have a problem when use code coverage mode. Below i descript the problem:
I compile (using .do file) lot of sources:
vlog -work $prjworklib -novopt -lint -cover bcsxf +incdir+$incdir+$rtldir $rtldir/preprocess/filter/filter_mult.v ... ...
After this, i run the simulation from Modelsim console (using .do file):
vsim -L altera_mf -coverage $prjsimlib/work.tb quietly WaveActivateNextPane {} 0 add wave -noupdate -divider {system} add wave -noupdate -format Logic -radix unsigned {/tb/reset} add wave -noupdate -format Logic -radix unsigned {/tb/sys_clk} ... ... TreeUpdate update run -all
Next, in modelsim i got coverage reports with some coverage results.
The problem:
When i try to open coveraged file using double click on non-coveraged code section or using file--open menu (see screenshot) - modelsim cannot open the file and i get error numeric coverage display disabled
http://electronix.ru/forum/style_images/1/img-resized.png Уменьшено до 77%
http://electronix.ru/forum/uploads/monthly_03_2016/post-1437-1458625293_thumb.png (http://electronix.ru/forum/index.php?act=attach&type=post&id=99559) 1363 x 766 (129.53 килобайт)
Please help me to solve it.
Thanks! :)
