17253 Discussions
If the logic of an Output pin in the design is set to LOW, and the pin is set to Assignment Editor/Weak Pull-Up Resistor = On in QuartusII, what happens to the I/O pin?
KJalte2
Please refer to the attached file.
AnandRaj_S_Intel
>>output is logic Logic LOW.
Output pin in the design is set to HIGH, and the pin is set to Assignment Editor/Weak Pull-Up Resistor
>>output is logic Logic HIGH
 Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
regards
Anand.
