17267 Discussions
Implementing a program counter
Hello!
Im implementing a CPU, so i need a PC (program counter). My instructions are at PC because we dont need to have a memory.
My problem is:
My BEQ instruction is delayed by one instruction
(BEQ is like something, if register1 = register2 then jump)
Example:
move r1,10 <- execute
move r2,10 <-execute
beq r1,r2,line5 <-execute
add r1,r2 <- execute and jump
move r3,r1
line5: sub r1,r2 <- continue...
i dont know why it is executing the next instruciton (add) then jumping.
Is it a delay problem?
thanks in advance.
I'm Using quartus web edition.
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; entity PC is port( input : in std_logic_vector(7 downto 0); output : out std_logic_vector(7 downto 0); PCin :in std_logic; address : in std_logic_vector(3 downto 0); PCJR: in std_logic; PCJump: in std_logic; BEQ: in std_logic; BEQ_control : in std_logic; clock : in std_logic; indice : out std_logic_vector(7 downto 0) ); end PC; architecture logic of PC is type instructions is array(0 to 8) of std_logic_vector(7 downto 0); signal ins : instructions; --signal aux : std_logic_vector(7 downto 0); --signal canJump : std_logic; begin --Instructions ins(0) <= "11000001"; ins(1) <= "11001011"; ins(2) <= "00100011"; ins(3) <= "11000010"; ins(4) <= "11011010"; ins(5) <= "11011110"; ins(6) <= "11011001"; ins(7) <= "11000101"; ins(8) <= "01100110"; process(clock) variable ind : integer :=0; begin if(clock'event and clock = '1') then if(PCin = '1') then -- send instruction and increment output <= ins(ind); ind := ind + 1; --indice <= CONV_STD_LOGIC_VECTOR(ind,8); elsif(PCJR = '1') then -- JR ind := CONV_INTEGER(UNSIGNED(input)); elsif(PCJump = '1') then --JUmp ind := CONV_INTEGER(UNSIGNED(address)); elsif(beq = '1') then if(beq_control = '1') then -- PC - 8 ind := ind - (CONV_INTEGER(UNSIGNED(address))); else --PC + 8 ind := ind + (CONV_INTEGER(UNSIGNED(address))); --indice <= CONV_STD_LOGIC_VECTOR(ind,8); end if; end if; --output <= aux; end if; ind := ind; end process; end logic;
Using variables is usually a bad coding style.
I do not understand why many instructions are commented out. Please edit the code above to remove lines that are not meant to be there.
You do not need the instruction ind := ind; in the end. It does not do anything.
Here it is.
But my ind is the position of the array
i mean like in C vet[i]
If it isnt good, what can i do ?
i don't think i can do this with std_logic, or bit. or i can?
thanks
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; entity PC is port( input : in std_logic_vector(7 downto 0); output : out std_logic_vector(7 downto 0); PCin :in std_logic; address : in std_logic_vector(3 downto 0); PCJR: in std_logic; PCJump: in std_logic; BEQ: in std_logic; BEQ_control : in std_logic; clock : in std_logic; indice : out std_logic_vector(7 downto 0) ); end PC; architecture logic of PC is type instructions is array(0 to 8) of std_logic_vector(7 downto 0); signal ins : instructions; begin --Instructions ins(0) <= "11000001"; ins(1) <= "11001011"; ins(2) <= "00100011"; ins(3) <= "11000010"; ins(4) <= "11011010"; ins(5) <= "11011110"; ins(6) <= "11011001"; ins(7) <= "11000101"; ins(8) <= "01100110"; process(clock) variable ind : integer :=0; begin if(clock'event and clock = '1') then if(PCin = '1') then -- send instruction and increment output <= ins(ind); ind := ind + 1; elsif(PCJR = '1') then -- JR ind := CONV_INTEGER(UNSIGNED(input)); elsif(PCJump = '1') then --JUmp ind := CONV_INTEGER(UNSIGNED(address)); elsif(beq = '1') then if(beq_control = '1') then -- PC - 8 ind := ind - (CONV_INTEGER(UNSIGNED(address))); else --PC + 8 ind := ind + (CONV_INTEGER(UNSIGNED(address))); end if; end if; end if; end process; end logic;
I asked you to edit the first post, not to post a second one :)
And now you removed so much code that I doubt that the code does anything at all.
I dont quite understand your problem. From your code the output only changes when PCin is high, and it outputs whatever the last instruction was.
This PC entity always send to my CPU the next instruction
