Hello!
Im implementing a CPU, so i need a PC (program counter). My instructions are at PC because we dont need to have a memory. My problem is: My BEQ instruction is delayed by one instruction (BEQ is like something, if register1 = register2 then jump) Example: move r1,10 <- execute move r2,10 <-execute beq r1,r2,line5 <-execute add r1,r2 <- execute and jump move r3,r1 line5: sub r1,r2 <- continue... i dont know why it is executing the next instruciton (add) then jumping. Is it a delay problem? thanks in advance. I'm Using quartus web edition.library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity PC is
port(
input : in std_logic_vector(7 downto 0);
output : out std_logic_vector(7 downto 0);
PCin :in std_logic;
address : in std_logic_vector(3 downto 0);
PCJR: in std_logic;
PCJump: in std_logic;
BEQ: in std_logic;
BEQ_control : in std_logic;
clock : in std_logic;
indice : out std_logic_vector(7 downto 0)
end PC;
architecture logic of PC is
type instructions is array(0 to 8) of std_logic_vector(7 downto 0);
signal ins : instructions;
--signal aux : std_logic_vector(7 downto 0);
--signal canJump : std_logic;
begin
--Instructions
ins(0) <= "11000001";
ins(1) <= "11001011";
ins(2) <= "00100011";
ins(3) <= "11000010";
ins(4) <= "11011010";
ins(5) <= "11011110";
ins(6) <= "11011001";
ins(7) <= "11000101";
ins(8) <= "01100110";
process(clock)
variable ind : integer :=0;
begin
if(clock'event and clock = '1') then
if(PCin = '1') then -- send instruction and increment
output <= ins(ind);
ind := ind + 1;
--indice <= CONV_STD_LOGIC_VECTOR(ind,8);
elsif(PCJR = '1') then -- JR
ind := CONV_INTEGER(UNSIGNED(input));
elsif(PCJump = '1') then --JUmp
ind := CONV_INTEGER(UNSIGNED(address));
elsif(beq = '1') then
if(beq_control = '1') then
-- PC - 8
ind := ind - (CONV_INTEGER(UNSIGNED(address)));
else
--PC + 8
ind := ind + (CONV_INTEGER(UNSIGNED(address)));
end if;
end if;
--output <= aux;
end if;
ind := ind;
end process;
end logic;
Using variables is usually a bad coding style.
I do not understand why many instructions are commented out. Please edit the code above to remove lines that are not meant to be there. You do not need the instruction ind := ind; in the end. It does not do anything.- Mark as New
Here it is.
But my ind is the position of the array i mean like in C vet[i] If it isnt good, what can i do ? i don't think i can do this with std_logic, or bit. or i can? thankslibrary ieee;
entity PC is
port(
PCin :in std_logic;
PCJR: in std_logic;
BEQ: in std_logic;
end PC;
begin
--Instructions
process(clock)
begin
output <= ins(ind);
ind := ind + 1;
-- PC - 8
else
--PC + 8
end if;
end if;
end if;
end process;
end logic;
I asked you to edit the first post, not to post a second one :)
And now you removed so much code that I doubt that the code does anything at all.- Mark as New
I dont quite understand your problem. From your code the output only changes when PCin is high, and it outputs whatever the last instruction was.
This PC entity always send to my CPU the next instruction
