17251 Discussions
Import VHDL package in (System)Verilog design
VolCoM
Here is my problem :
I have a package which is written in VHDL.
I would like to import it in my SystemVerilog design.
In Modelsim, I would simply compile the VHDL file with a special flag so it's compatible
=> vcom -mixedsvvh package.vhd
and then import it in my SystemVerilog file with
=> import package::*;
And everything works fine during the simulation.
In Quartus, I can't find any way to make the VHDL package compatible with my SV design.
When I try to compile in Quartus, I get the following error :
Error (10161): Verilog HDL error at SystemVerilogDesign.sv(4): object "package" is not declared. Verify the object name is correct. If the name is correct, declare the object.
  • My SV design is properly configured as a SystemVerilog file.
  • The name of my VHDL package is in lower case so it should not be a case problem.
It is exactly the same problem as described in this link from 3 years ago :
https://forums.intel.com/s/question/0D50P00003yyS9gSAE/error-10161-when-importing-vhdl-packages-to-system-verilog?language=en_US
Thank you for any information that could help !
Prashant_Sharma
Hi there, did you find any solution ?
