17260 Discussions
In Quartus we set the VHDL version with Settings -> Compiler Settings -> VHDL Input. How to inform the platform viewer about the VHDL version?
MakV
I am using the custom types and written those in the package. I am using them unconstrained like below
type mydatatype is array (integer range <>) of unsigned;
And with the settings the VHDL version to 2008, I could analyze and synthesize in Quartus. I would like to make component with the code I have written so that can be used in the Platform Generator. So when I try to do that, I get an error
element type for array type cannot be unconstrained
How to set the VHDL version in Platform Generator to get rid of the error?
Best Regards
JOHI
New Contributor II
In Quartus go to Assignments / Settings
And in the settings dialog box go to Compiler Settings / Vhdl input.
Johi.
MakV
I am already using the settings in Quartus. I want to use the same sources and make a Qsys-component.
My question was how to set the VHDL version in Platform Generator(Qsys).
KhaiChein_Y_Intel
Hi MakV,
May I know what edition (Standard/Pro) and version you are using?
MakV
KhaiChein_Y_Intel
Hi MakV, Referring to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/po/ss-quartus-comparison.pdf, VHDL 2008 is not supported in the Standard edition. Thanks.
