IP Upgrade fails
EIbra
Quartus 18.1
project from Quartus 16 with altsyncram
1) Open project, upgrading with GUI - MegaWizard hangs.
one IP is not upgradable - altsyncram
2)
quartus_sh --ip_upgrade -mode all test_header
result
... Info: Command: quartus_sh --ip_upgrade -mode all test_header Info: Quartus(args): -mode all test_header ------------------------------------------------   while executing "regenerate_ip -all" (procedure "upgrade_ip_cores_flow" line 6) invoked from within "upgrade_ip_cores_flow $mode" (procedure "main" line 24) invoked from within "main" (file "/opt/intelFPGA_lite/18.1/quartus/common/tcl/internal/ip_regen/ip_regen.tcl" line 340) ------------------------------------------------ Error (23031): Evaluation of Tcl script /opt/intelFPGA_lite/18.1/quartus/common/tcl/internal/ip_regen/ip_regen.tcl unsuccessful Error: Quartus Prime Shell was unsuccessful. 1 error, 0 warnings
rom_init_spi.qip:
set_global_assignment -name IP_TOOL_NAME "ROM: 1-PORT" set_global_assignment -name IP_TOOL_VERSION "16.0" set_global_assignment -name IP_GENERATED_DEVICE_FAMILY "{Cyclone V}" set_global_assignment -name VERILOG_FILE [file join $::quartus(qip_path) "rom_init_spi.v"]
.v file attached
how to fix it?
AnandRaj_S_Intel
I have tested using Quartus 13.0 and generated altsyncram and updated IP to Quartus 17.1 & Quartus 18.1 with out any error.
Can you again by deleting db and incremental_db folders with GUI or command line.
  1. Select the IP core in the Upgrade IP Components dialog box.
  2. Click Upgrade in Editor. The parameter editor appears.
  3. Click Finish or Generate to regenerate the IP variation and complete the upgrade. The version number updates when complete.
or
  1. Use quartus_sh -ip_upgrade -variation_files <file.vhd/.v> <projectname>
If possible attach by archive project?
Reference-> session 1.5 https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_intro_to_megafunctions.pdf
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand
EIbra
thank you,
this helps
