17252 Discussions
In-System Sources and Probes Crash on Linux
Using Quartus II 12.1 on Linux (tried both Ubuntu 12.04 and OpenSUSE 12.2) and get the following crash when trying to launch in-system sources and probes. Anybody know a fix/workaround?
Jay
*** Fatal Error: Segment Violation at 0x20d
Module: quartus
Stack Trace:
0x44148: BNLQ_DATA_TABLE_VIEW::update_table_column(unsigned int) + 0x208 (sld_bnlq)
0x444fd: BNLQ_NODE_WIDGET::update_table_view(unsigned int) + 0x39 (sld_bnlq)
0x4579b: BNLQ_DATA_WIDGET::update_node_view(unsigned int) + 0xbb (sld_bnlq)
0x4588e: BNLQ_WIDGET::on_update(unsigned int) + 0xda (sld_bnlq)
0x4769f: BNLQ_LAYOUT_WIDGET::update_all_widgets(QWidget*, unsigned int) + 0x41 (sld_bnlq)
0x4e236: BNLQ_DATA_TABLE_VIEW::draw_timebar() + 0x104 (sld_bnlq)
0x52252: BNLQ_DATA_TABLE_VIEW_HEADER::mouseMoveEvent(QMouseEvent*) + 0x22a (sld_bnlq)
0x1aeb11: QWidget::event(QEvent*) + 0x611 (QtGui.so.4)
0x5b70f3: QFrame::event(QEvent*) + 0x33 (QtGui.so.4)
0x656392: QAbstractScrollArea::viewportEvent(QEvent*) + 0x32 (QtGui.so.4)
0x710265: QAbstractItemView::viewportEvent(QEvent*) + 0x525 (QtGui.so.4)
0x1798c1: QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) + 0x91 (QtCore.so.4)
0x1489a3: QApplicationPrivate::notify_helper(QObject*, QEvent*) + 0x93 (QtGui.so.4)
0x151104: QApplication::notify(QObject*, QEvent*) + 0x18f4 (QtGui.so.4)
0x17947b: QCoreApplication::notifyInternal(QObject*, QEvent*) + 0x7b (QtCore.so.4)
0x14b9a2: QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) + 0xf2 (QtGui.so.4)
0x1dafe6: QApplication::x11ProcessEvent(_XEvent*) + 0x1966 (QtGui.so.4)
0x17850d: QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0x4d (QtCore.so.4)
0x17879a: QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 0xaa (QtCore.so.4)
0x17a811: QCoreApplication::exec() + 0xb1 (QtCore.so.4)
0x148317: QApplication::exec() + 0x27 (QtGui.so.4)
0x633f: __gxx_personality_v0 + 0x373 (quartus)
0x23208: msg_main_thread(void*) + 0x18 (ccl_msg)
0x5e5e: thr_final_wrapper + 0xe (ccl_thr)
0x23f1b: msg_thread_wrapper(void* (*)(void*), void*) + 0x6c (ccl_msg)
0x1591d: mem_thread_wrapper(void* (*)(void*), void*) + 0xdd (quartus)
0xffd8: err_thread_wrapper(void* (*)(void*), void*) + 0x2a (ccl_err)
0x62ba: thr_thread_wrapper + 0x2f (ccl_thr)
0x367c7: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xb7 (ccl_msg)
0x6411: __gxx_personality_v0 + 0x445 (quartus)
0x193d5: __libc_start_main + 0xf5 (c.so.6)
0x61f1: __gxx_personality_v0 + 0x225 (quartus)
End-trace
Quartus II 32-bit Version 12.1 Build 177 11/07/2012 SJ Web Edition
Hi, we were able to reproduce the issue in house. I believe it only occurs with 32-bit. Are you able to use 64-bit Web Edition?
Oh yes, you are right. It crashes in 32bit, but does not in 64bit. Thanks!!
I am using Quartus 32 bit version 13.1.4 build 182 on linux
When I try to use the in system source and probes editor Quartus chrashes when I load the .sof file
also the in system source and probes editor cannot find any instances of the probes mega function
even though it is compiled into the source.
Phil sharrock
