I'm trying to write a synchronous FIFO in VHDL, and I get the following message :
Info (276007): RAM logic "sRAM" is uninferred due to asynchronous read logic I already asked google, and did some modification to my code, but without success. Here is the code :architecture arch of fifo is
type ram_t is array (0 to depth) of std_logic_vector(data_in'range);
signal sRAM : ram_t;
signal sRead_ptr : unsigned(unsigned_num_bits(depth-1)-1 downto 0) := (others => '0');
signal sWrite_ptr : unsigned(unsigned_num_bits(depth-1)-1 downto 0) := (others => '0');
begin
pRam : process(clk) is
begin
if rising_edge(clk) and EN = '1'then
if W = '1' then
sRam(to_integer(sWrite_ptr)) <= data_in;
if sWrite_ptr > to_unsigned(depth, sWrite_ptr'length) then
sWrite_ptr <= (others => '0');
else
sWrite_ptr <= sWrite_ptr + 1;
end if;
end if;
if R = '1' then
if sRead_ptr > to_unsigned(depth, sRead_ptr'length) then
sRead_ptr <= (others => '0');
else
sRead_ptr <= sRead_ptr + 1;
end if;
end if;
end if;
end process pRam;
data_out <= sRam(to_integer(sRead_ptr));
end architecture arch;
How can I modify my code for quartus to infer my RAM ?
No clue, actually. That looks inferrable to me.
My suggestion: start with the basic template from the HDL coding guidelines, and work from there. Which FPGA are you using? There are some differences between M4K and M9K blocks, though they shouldn't affect you here.- Mark as New
The problem is i think in using the readptr as asynchronous address AND doing calculations on it. If you put the read statement inside the process it willl probalby infer (but with slightly different behaviour of course). Worth a try?
Review the paragraph inferring memory functions from hdl code in the Altera software handbook or the Quartus editor VHDL templates. They are expecting the read action data_out <= sram(to_integer(sread_ptr)); inside a clock edge sensitive block.
In fact, in the first design I tried, the reading was in the process and it didn't infer. When I googled it I found that it has to be outside (http://www.alteraforum.com/forum/showthread.php?t=28242).
But now I found a solution. I first put an inferable ram block (thanks to the previous thread), and then I just rewrite it.architecture arch of fifo is
type ram_t is array (0 to depth-1) of std_logic_vector(data_in'range);
signal sRam : ram_t;
signal sAddr_read : std_logic_vector(sRead_ptr'range);
begin
begin
if rising_edge(clk) then
if W = '1' then
end if;
sAddr_read <= std_logic_vector(sRead_ptr);
end if;
end process pRam;
data_out <= sRam(to_integer(unsigned(sAddr_read)));
pRead_ptr : process(clk) is
begin
if R = '1' then
if sRead_ptr > to_unsigned(depth-2, sRead_ptr'length) then
else
end if;
end if;
end if;
end process pRead_ptr;
pWrite_ptr : process(clk) is
begin
if W = '1' then
if sWrite_ptr > to_unsigned(depth-2, sWrite_ptr'length) then
else
end if;
end if;
end if;
end process pWrite_ptr;
