Inferring FIFO in VHDL
I'm trying to write a synchronous FIFO in VHDL, and I get the following message :
Info (276007): RAM logic "sRAM" is uninferred due to asynchronous read logic
I already asked google, and did some modification to my code, but without success.
Here is the code :
architecture arch of fifo is type ram_t is array (0 to depth) of std_logic_vector(data_in'range); signal sRAM : ram_t; signal sRead_ptr : unsigned(unsigned_num_bits(depth-1)-1 downto 0) := (others => '0'); signal sWrite_ptr : unsigned(unsigned_num_bits(depth-1)-1 downto 0) := (others => '0'); begin pRam : process(clk) is begin if rising_edge(clk) and EN = '1'then if W = '1' then sRam(to_integer(sWrite_ptr)) <= data_in; if sWrite_ptr > to_unsigned(depth, sWrite_ptr'length) then sWrite_ptr <= (others => '0'); else sWrite_ptr <= sWrite_ptr + 1; end if; end if; if R = '1' then if sRead_ptr > to_unsigned(depth, sRead_ptr'length) then sRead_ptr <= (others => '0'); else sRead_ptr <= sRead_ptr + 1; end if; end if; end if; end process pRam; data_out <= sRam(to_integer(sRead_ptr)); end architecture arch;How can I modify my code for quartus to infer my RAM ?
No clue, actually. That looks inferrable to me.
My suggestion: start with the basic template from the HDL coding guidelines, and work from there.
Which FPGA are you using? There are some differences between M4K and M9K blocks, though they shouldn't affect you here.
The problem is i think in using the readptr as asynchronous address AND doing calculations on it. If you put the read statement inside the process it willl probalby infer (but with slightly different behaviour of course). Worth a try?
Review the paragraph inferring memory functions from hdl code in the Altera software handbook or the Quartus editor VHDL templates. They are expecting the read action data_out <= sram(to_integer(sread_ptr)); inside a clock edge sensitive block.
In fact, in the first design I tried, the reading was in the process and it didn't infer. When I googled it I found that it has to be outside (http://www.alteraforum.com/forum/showthread.php?t=28242).
But now I found a solution. I first put an inferable ram block (thanks to the previous thread), and then I just rewrite it.
architecture arch of fifo is signal sRead_ptr : unsigned(unsigned_num_bits(depth-1)-1 downto 0) := (others => '0'); signal sWrite_ptr : unsigned(unsigned_num_bits(depth-1)-1 downto 0) := (others => '0'); type ram_t is array (0 to depth-1) of std_logic_vector(data_in'range); signal sRam : ram_t; signal sAddr_read : std_logic_vector(sRead_ptr'range); begin pRam : process(clk) is begin if rising_edge(clk) then if W = '1' then sRam(to_integer(sWrite_ptr)) <= data_in; end if; sAddr_read <= std_logic_vector(sRead_ptr); end if; end process pRam; data_out <= sRam(to_integer(unsigned(sAddr_read))); pRead_ptr : process(clk) is begin if rising_edge(clk) and EN = '1'then if R = '1' then if sRead_ptr > to_unsigned(depth-2, sRead_ptr'length) then sRead_ptr <= (others => '0'); else sRead_ptr <= sRead_ptr + 1; end if; end if; end if; end process pRead_ptr; pWrite_ptr : process(clk) is begin if rising_edge(clk) and EN = '1'then if W = '1' then if sWrite_ptr > to_unsigned(depth-2, sWrite_ptr'length) then sWrite_ptr <= (others => '0'); else sWrite_ptr <= sWrite_ptr + 1; end if; end if; end if; end process pWrite_ptr; end architecture arch;
