Hello everyone, I am currently designing 8-bit resolution Sinusoidal Wave Generator. I chose the look-up table method which needs a ROM module (256x8bit). I am using verilog coding and synthesize using Quartus II 9.1 on cyclone II device family. Here is my sub-module for the look-up table :
module LUT256 (
ADDR, // Address input
DataOut, // Data output
RE, // Read Enable
CE // Chip Enable
) /* synthesis romstyle = "M4K" */;
input ADDR;
output DataOut;
input RE,CE;
(* romstyle = "M4K" *) reg mem ;
wire DataOut;
assign DataOut = (CE && RE) ? mem : 8'b0;
initial begin
$readmemb("sine_value.list", mem); // sine_value is pre-calcualted value
end
endmodule
The problem is, when I view the Technology Map Viewer (post mapping), the sub-module doesn't synthesize into ROM but instead into logic cells. RTL Viewer shows that the sub-module synthesized into memory module though. I also changed the appropriate settings in Quartus II analysis&synthesis settings for ROM/RAM to infer ROM/RAM module. Can someone please explain how to fix this problem. Thank you in advance.
I think you need to add a clk. I had this problem too and the solution was to make the memory bigger, so you might want to try that as well.
--- Quote Start --- I think you need to add a clk. --- Quote End --- Exactly. View the Verilog language templates in Quartus editor, they have examples of RAM and ROM inference. The requirements are also explained in detail in the Quartus software handbook.
Thanks everyone for helping me. I managed to solve the problem by adding clock to the module. Here's the final code :
module LUT256DFF (
Clk,
RE, // Read Enable
CE // Chip Enable
input Clk;
input ADDR;
output DataOut;
input RE,CE;
reg DataOut;
always @ (posedge Clk)
begin
if (CE && RE)
DataOut <= mem;
end
initial begin
$readmemb("sine_value.list", mem); // sine_value is pre-calcualted external memory file
end
endmodule
It will synthesize to 2048bits of RAM (altsyncram). One question, is this RAM has the same attribute with the cyclone II's M4K ROM ?
