17267 Discussions
Insalling ByteBlasterMV driver on Debian
The Version of Quartions i have is intended to run on RedHat, but i'm using Debian.
I'm trying to install QuartusII Software on Debian, the following message appears after running make install:
:/opt/altera7.1/quartus/linux/byteblaster# make install
install -d /lib/modules/2.4.27-2-386/kernel/misc/
install -c byteblaster.o /lib/modules/2.4.27-2-386/kernel/misc/byteblaster.o
install -c jtagd-init /etc/init.d/jtagd
update-rc.d jtagd defaults
System startup links for /etc/init.d/jtagd already exist.
/sbin/depmod -aq
/etc/init.d/jtagd start
/etc/init.d/jtagd: line 12: /etc/rc.d/init.d/functions: Aucun fichier ou répertoire de ce type
make: *** [install] Erreur 1
Hi everybody;
It's funny to ask a question then answer it by myself.
So;; here is the solution.
the file " /etc/rc.d/init.d/functions" is intented to be found on RedHat Distribution.
Its Equivalent on Debian is : "/lib/lsb/init-functions"
So, enjoy your selves.
