17268 Discussions
Installing Quartus II 11.1 SP2 Web Edition to WinXP SP2 x64 Pro
I've been able to install Quartus 11.1 SP2 Web Edition on a machine running WinXP SP2 32-bit. However, when I try to install the same exact file to a machine running WinXP SP2 x64 Professional Edition, I encounter the following error almost immediately during the installation:
"WindowsError: [Error 5] Access is denied"
After a bit of googling, I've learned it may be that this is related to running a 32-bit python installer on a 64-bit machine. Apparently there are some issues with 32-bit python accessing the registry in this situation. I don't know if this truly is the source of the problem, but I thought I'd throw it out there.
Has anyone been able to install the 32-bit version of Quartus to a 64-bit version of WinXP? If so, how did you do it?
--tim
I've opened up an SR for this. The response from them has been poor at best.
Has anybody else out there tried to install Quartus II Web Edition to a machine running WinXP x64? I can't be the only one here, can I?
--tim
After contacting support, I was asked to attempt the workaround suggested here. That seems to have cured my problem.
http://support.microsoft.com/kb/925336
In case that URL disappears, you need to edit the registry by going to:
HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\Safer\CodeIdentifiers
Change PolicyScope from 0 to 1. After installation, change it back to 0.
--tim
