Integer as an array.
I am using an integer to count pulses and then need to give it to an 7 Segment display.
Can I use the Integer variable as an array directly , and read each place's value ?
The highlighted statement gives an error.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.all;
entity newcounter is
Port ( clk : in std_logic;
HEX0,HEX2, HEX1: out std_logic_vector(6 downto 0):= "1111110" );
end entity;
architecture Behavioral of newcounter is
signal temp0,temp1,temp2: integer :=0;
begin
process (clk) is
type seven_seg is array ( 0 to 9 ) of std_logic_vector ( 6 downto 0 );
constant decode : seven_seg := ( "1000000" , "1111001" , "0100100" , "0110000" , "0011001" , "0010010" ,
"0000010" , "1111000" , "0000000" , "0010000" );
variable count: integer:=0;
begin
if rising_edge(clk) then count := count + 1;
end if;
temp0 <= count(0);
HEX0 <= decode( temp0);
end process;
end Behavioral;
no, an integer is not an array, so you cannot do this. And anyway, you could not take an integer from it even if you could - it would be a single bit.
to get access to the single bits, you need to convert it to an array type - easiest would be signed or unsigned:
signal temp : std_logic;
temp <= to_signed(count, 1)(0);
I get the following error -
Error (10476): VHDL error at newcounter.vhd(32): type of identifier "temp0" does not agree with its usage as integer type.
The snippet is
temp0 <= to_signed(count, 1)(0);
HEX0 <= decode(temp0);
with the rest same as above.
Hi, read/understand the error and look at the code :cool:
remove temp0 form the line "signal temp0,temp1,temp2: integer :=0;"
add the line "signal temp : std_logic;" (from Tricky) just under
And write
temp <= to_signed(count, 1)(0); HEX0 <= decode(temp0);
outside the process
OR write
process (clk) is -- variable declarations begin if rising_edge(clk) then count := count + 1; temp0 <= to_signed(count, 1)(0); HEX0 <= decode( temp0); end if; end process;
By this last way, you will produce register and then latence : count --> temp0 --> decode
(outside the "if rising_edge(clk)...end if;", you will get very unexpected results !)
You need to be more rigorous :-P and get good basis in VHDL (Altera vhdl style guide line....)
