17252 Discussions
Where is the clock (CLK) in Quartus schematic entry?
I'm new to the quartus design software and have been entering small designs (so far) in the integrated *.bdf schematic editor (you know, where you wire simple gates together).
The design I'm working on right now requires a clock signal,which will run at something like 0.5-10 Hz. The design will be downloaded to a DE2-115 board.
So far as I can tell, the "Symbol Tool" library in the block diagram editor doesn't contain a variable speed (or any other) clock. Is the normal solution to build a clock as a verilog module and then import it?
Any suggestions would be appreciated!
The clock is like any other pin. You place an IN port and then connect it to the clock input of a flip-flop, register, etc. I don't remember, but DE2 probably have a 50MHz clock, so if you need 10Hz you have slow down with a counter.
