May I know which Quartus version and the Questa version that you are using?
I found from here that:
https://docplayer.net/219167054-Questa-intel-fpga-edition-quick-start.html
"This error is issued when the design capacity for Questa-Intel FPGA Edition simulator is exceeded. By default, the simulator does not preserve signals for waveform viewing.... Preserve signals explicitly by specifying vsim or vopt options, such as +acc. "
Not sure if this works for you. If the solution does not work, please help to share me the Quartus design .qar project file (Project> Achieve Project) so I can investigate on this issue.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
I found there is a case duplicate here:
We do not recommend to have another case duplicate and recommend to close one of it.
Richard Tan
As there is a duplicate case, I now transition this thread to community support.
Thank you.
Richard Tan
