17252 Discussions
Intel HLS link x86-64 failed
ali21
I ran the example in quartus18.0 and it terns out the LNK1107 error
C:\intelFPGA_std\18.0\hls\examples\counter>build test-x86-64 i++ -march=x86-64 counter.cpp -o test-x86-64.exe c:/program files (x86)/microsoft visual studio 14.0/vc/bin/link.exe : fatal erro r LNK1107: 文件无效或损坏: 无法在 0x320 处读取 HLS Link x86-64 FAILED. Run test-x86-64.exe to execute the test.
And I tried quartus_18.1_pro and VS2015 pro on a new installed windows7 system, same problem showed up.
Can any body tell me what's wrong and how to fix it?​
KhaiChein_Y_Intel
Hi ali21,
1) Are you following the HLS Starting Guide? Did you run the init_hls.bat first? User need to run this *.bat before any compilation as it will setup the environment.
2) Could you check if you have link.exe in c:/program files (x86)/microsoft visual studio 14.0/vc/bin ?
3) This error states that user is adding a 32 bit link file for usage which is incorrect, HLS requires the 64 bit link file. \VC\bin\amd64\link.exe
ali21
​I did have used 32 bit link file . Thanks very much.
