Simulating gate delays
appu69
Hey!
I recently started using Intel Quartus Prime Lite edition for simulating Verilog codes.
I came across the topic of gate delays in a book..
for eg. In a verilog code if I write a line of code as such :
module simple_circuit(A, B, C, D, E);
input A, B, C;
output D, E;
and #30 G1 (w1, A, B);
not #10 G2 (E,C);
or #20 G3 (D, w1, E);
endmodule
how do I view the simulation of gate delays.?
AnandRaj_S_Intel
Look into example from below link.
https://wiki.eecs.yorku.ca/course_archive/2012-13/F/3201/_media/tutorial_quartusii_timing_simulation_verilog.pdf
If you are using modelsim/VWF
Launch gate level simulation from tools/VWF->Run simulation Tools->Gate level/timing simulation. Before that you need to setup path go to tools->options->EDA Tools option->modelsim altera ->give the modelsim path example "C:\intelFPGA\17.0\modelsim_ase\win32aloem".
You can find more useful information from previous threads kindly check below threads.
https://forums.intel.com/s/question/0D50P00003yyIOXSA2/i-have-problem-with-functional-simulation-with?language=en_US
https://forums.intel.com/s/question/0D50P00003yyGJwSAM/help-whats-the-difference-between-functional-simulation-and-timing-one?language=en_US
Anand
