17252 Discussions
Interface for external RAM and LPM RAM
I switched to Quartus 9.0 from 6.1.
I used "Interface to User Logic" for external RAM(MRAM) and LPM RAM.
Instead of them, I added new components in SOPC Builder.
Is there any problem in VHDL discription?
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity MRAM is
port (
address : in std_logic_vector(17 downto 0) ; --avalon_tristate_slave.address
data : inout std_logic_vector(15 downto 0) ; -- .data
byteenable_n : in std_logic_vector(1 downto 0) ; -- .byteenable_n
chipselect_n : in std_logic ; -- .chipselect_n
read_n : in std_logic ; -- .read_n
write_n : in std_logic ; -- .write_n
add : out std_logic_vector(17 downto 0); -- conduit_end.export
dat : inout std_logic_vector(15 downto 0) ;
be_n : out std_logic_vector(1 downto 0);
cs_n : out std_logic ;
oe_n : out std_logic ;
we_n : out std_logic
end entity MRAM;
architecture rtl of MRAM is
begin
add <= address;
be_n <= byteenable_n;
cs_n <= chipselect_n;
oe_n <= read_n;
we_n <= write_n;
dat <= data;
end architecture rtl; -- of MRAM
In your vhdl code, the connection between data and dat is unidirectional, which is probably not what you intended.
But why are you using vhdl in the first place? Can't you define your external RAM as a tristate slave and just declare all the signals that you need?
Thanks for reply.
I had a problem that only data port was export when I created a tristate slave.
showthread.php?p=88948 (I can't post links)
So I had to write HDL code but the problem was resolved just now.
It was mainly with my own circuit. VHDL code is here.
-- MRAM.vhd
library IEEE;
entity MRAM is
port (
data : inout std_logic_vector(15 downto 0) := (others => '0'); -- avalon_tristate_slave.data
byteenable_n : in std_logic_vector(1 downto 0) := (others => '0'); -- .byteenable_n
chipselect_n : in std_logic := '0'; -- .chipselect_n
read_n : in std_logic := '0'; -- .read_n
write_n : in std_logic := '0'; -- .write_n
address : in std_logic_vector(17 downto 0) := (others => '0'); -- .address
be_n : out std_logic_vector(1 downto 0); -- .export
cs_n : out std_logic; -- .export
oe_n : out std_logic; -- .export
wr_n : out std_logic -- .export
end entity MRAM;
begin
add <= address;
oe_n <= read_n;
wr_n <= write_n;
