17268 Discussions
Internal Error : Expected to get 1 pll but found 3 plls for group EMIF_0_mem_ctrl_alt
My design contains several PLL's :
- a PLL to generate the main system clock.
- a PLL for the DDR controller.
- a PLL in a PCIe interface IP.
Recently my builds have been crashing with an internal error :
Problem Details
Error:
Internal Error: Sub-system: EMIF, File: /quartus/periph/emif/emif_gen6_emif_system.cpp, Line: 2645
Expected to get 1 pll but found 3 plls for group EMIF_0_mem_ctrl_altera_emif_170_wp4gjuy
After I do Project->Clean project, the build succeeds.
PLL Usage Summary in the .fit.rpt lists :
DDR_NODE: DDR_NODE_inst_0|mem_ctrl:mem_ctrl|mem_ctrl_altera_emif_161_x274mry:emif_0|mem_ctrl_altera_emif_arch_nf_161_bkdrrci:arch|mem_ctrl_altera_emif_arch_nf_161_bkdrrci_top:arch_inst|altera_emif_arch_nf_pll: pll_inst|pll_inst~_Duplicate_1
CLK_GEN_NETWORK:PLL_CLK_GEN|CLK_GEN_NETWORK_altera_iopll_161_octysbi:iopll_0|altera_iopll:altera_iopll_i|twentynm_iopll_ip:twentynm_pll|iopll_inst
PCIE_XL_INTERFACE:PCIE_TREETOP|xillybus:xillybus_ins|pcie_a10_8x: pcie|pcie_reconfig: pcie_reconfig|pcie_reconfig_altera_pcie_a10_hip_161_5uv7uhy: pcie_a10_hip_0|altpcie_a10_hip_pipen1b:altpcie_a10_hip_pipen1b|altpcie_a10_hip_pllnphy:g_xcvr.altpcie_a10_hip_pllnphy|fpll_g1g2xn:g_pll.g_pll_g12n.fpll_g1g2xn|altera_xcvr_fpll_a10:fpll_g1g2xn|fpll_inst
Whats up with the the duplicate PLL's?
Do they cause the internal error?
The target device is Arria 10/10AX115N3F45E2SG
I currently use Quartus 17.02, but the same error occurred in 16.1.2 and 16.0.2.
Full error report :
Problem Details
Error:
Stack Trace:
0xaccff: EMIF_GEN6_EMIF_SYSTEM::create_emif_phylite_group_cell() + 0x481 (periph_emif)
0xb3b8b: EMIF_GEN6_EMIF_SYSTEM::create_emif_cells(CDB_ATOM_NODE*, std::unordered_map<unsigned int, CDB_ATOM_NODE*, STL_HASH_FUNCTOR<unsigned int>, std::equal_to<unsigned int>, std::allocator<std:: pair<unsigned int const, CDB_ATOM_NODE*> > >&) + 0x1ab (periph_emif)
0x833c1: EMIF_GEN6::create_design() + 0x107 (periph_emif)
0x68496: PCC_ENV_IMPL:: perform_op(PCC_ENV::OP) + 0x1f6 (periph_pcc)
0x695a5: PCC_ENV_IMPL::create_design() + 0x1b5 (periph_pcc)
0x698ea: PCC_ENV_IMPL::refresh_design_until_converged(bool) + 0x18a (periph_pcc)
0x69ac1: PCC_ENV_IMPL::refresh(PCC_ENV::CONTEXT, std::string const&, bool, bool) + 0xd1 (periph_pcc)
0x6a485: PCC_ENV_IMPL::load_design() + 0x105 (periph_pcc)
0x955a1: pcc_load_periph_design + 0x71 (periph_pcc)
0x51ec7: TclNRRunCallbacks + 0x47 (tcl8.6)
0x40131: pcc_load_periph_placer + 0x102 (periph_pcc)
0x536e7: TclEvalEx + 0x947 (tcl8.6)
0x539d6: Tcl_EvalEx + 0x16 (tcl8.6)
0x539fd: Tcl_Eval + 0x1d (tcl8.6)
0x1aeb5: atcl_tcl_eval(Tcl_Interp*, std::string const&) + 0x12d (ccl_atcl)
0x34c49: atcl_run_internal_tcl_cmd(Tcl_Interp*, std::string const&, bool) + 0x59 (ccl_atcl)
0x2354c: fit2_fit_plan_init + 0x23c (comp_fit2)
0x13086: fit2_fit_plan + 0x2ec (comp_fit2)
0xfb366: Tcl_FSEvalFileEx + 0x266 (tcl8.6)
0xfb47e: Tcl_EvalFile + 0x2e (tcl8.6)
0x11ebc: qexe_evaluate_tcl_script(std::string const&) + 0x382 (comp_qexe)
0x18dcf: qexe_do_tcl(QEXE_FRAMEWORK*, std::string const&, std::string const&, std::list<std::string, std::allocator<std::string> > const&, bool, bool) + 0x597 (comp_qexe)
0x19d7b: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x57e (comp_qexe)
0x3e06a: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x1065 (comp_qcu)
0x1c586: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x6b3 (comp_qexe)
0x3b75: qfit2_main(int, char const**) + 0xc5 (quartus_fit)
0x40720: msg_main_thread(void*) + 0x10 (ccl_msg)
0x602c: thr_final_wrapper + 0xc (ccl_thr)
0x407df: msg_thread_wrapper(void* (*)(void*), void*) + 0x62 (ccl_msg)
0xa559: mem_thread_wrapper(void* (*)(void*), void*) + 0x99 (ccl_mem)
0x8f92: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
0x63f2: thr_thread_wrapper + 0x15 (ccl_thr)
0x427e2: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xa3 (ccl_msg)
0x1ed1d: __libc_start_main + 0xfd (c.so.6)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: CentOS release
OS version: 6
Quartus Prime Information
Address bits: 64
Version: 17.0.2
Build: 602
Edition: Standard Edition
Probably you have a DDR interface that more than 40bits data width?
The duplicate PLL is expected because the EMIF use 3 I/O banks. For EMIF once the EMIF is place into the particular bank, it will use that bank I/O PLL to generate clocks for the I/O banks DDR signals.
you may refer to EMIF handbook
https://www.altera.com/documentation/hco1416493470528.html#hco1416492698401
Arria 10 EMIF Architecture: PHY Clock Tree section
Arria 10 EMIF Architecture: PLL Reference Clock Networks section
(This message was posted on behalf of Intel Corporation)
Yes the DDR is 576b wide.
But, how does that with the match the "After I do Project->Clean project, the build succeeds." ?
