17255 Discussions
Internal Error: Sub-system: FITCC
Hi guys,
i've a problem with my quartus 11.1 sp2. can somebody help me?
here is the error message:
internal error: sub-system: fitcc, file: /quartus/fitter/fitcc/fitcc_device.cpp, line: 114
loaded
stack trace:
0x3869c: fitcc_device::fitcc_device + 0x11c (fitter_fitcc)
0x7c2b3: fsac_device::fsac_device + 0x23 (fitter_fsac)
0x7c5cf: fsac_device_factory_fn + 0x3f (fitter_fsac)
0x3de32: fitcc_env::fitcc_env + 0x922 (fitter_fitcc)
0x4425c: fitcc_expert::fitcc_expert + 0x5c (fitter_fitcc)
0x47c9: fcuda_execute + 0x39 (fitter_fcuda)
0xb55d: fmain_start + 0x7cd (fitter_fmain)
0x1264b: qexe_get_command_line + 0x1c5b (comp_qexe)
0x1588d: qexe_process_cmdline_arguments + 0x5ad (comp_qexe)
0x159a1: qexe_standard_main + 0xa1 (comp_qexe)
0x1a48: msg_initializer::~msg_initializer + 0x118 (ccl_msg)
0x19ec: msg_initializer::~msg_initializer + 0xbc (ccl_msg)
0x53d4: mem_initializer::~mem_initializer + 0x244 (ccl_mem)
0x3379f: msg_exe_main + 0x8f (ccl_msg)
0x1652c: basethreadinitthunk + 0xc (kernel32)
0x2c520: rtluserthreadstart + 0x20 (ntdll)
end-trace
quartus ii 64-bit version 11.1 build 259 01/25/2012 sj full version
service pack installed: 2
Thanks a lot
marc
It is very unlikely that somebody here in this forum can help you with such a error message. The best way to deal with this is to create a service request with the Altera support.
you can also try to delete the db and incremental_db folders in your project and compile it again, sometimes it solves those kind of problems.
Did you get a solution yet?
I've also seen the same error when compiling the 10G Ethernet reference design.
I've submitted a service request with Altera, but am yet to hear anything.
Already tried deleting the db and incremental_db directories. Also has same behaviour on 32 and 64 bit versions - in the past I've seen errors occur with only 1 version.
