AHDL Quartus !
Any one has an idea how can I include "copy" my own library in quartus II 9.1 ! I need to use AHDL to simulate my design but i need to include my own library.
thanks
you need to add your library to the file list (project -> Add / remove files in project)
Thanks. I did it gave me this error.
Error: Text Design File syntax error: Text Design File contains '`' where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected
googling the error it says i should remove inst.tdf files. after I did that it gave me this error.
Error: Top-level design entity is undefined
any idea ?!
any reason you have to use AHDL?
--- Quote Start ---
--- Quote End ---
Quick guess: The '`' symbol is the wrong type of ' or ´ or `. My keyboard has these 3 which look the same but are not the same. I forgot which one is the right. Do eiher a copy paste from some code which works or trial and error.
