17246 Discussions
Internal Error: Sub-system: TDC, File: /quartus/tsm/tdc/tdc_accessories_delay_budget.
Anyone found a way to avoid hitting this internal error?
I've been hitting it more & more frequently, and can't seem to avoid it any longer. Since it takes ~45 mins for the build to get to the point where it hits this (& dies), it's eating a lot of my time.
Internal Error: Sub-system: TDC, File: /quartus/tsm/tdc/tdc_accessories_delay_budget.cpp, Line: 1991
edge_delay_data[edge_id].reference_ic_delay >= ic_delay - 10
Stack Trace:
0x14acd: TDC_ACCESSORIES_DELAY_BUDGET::use_saved_min_delay_budget_calculation_starting_points_to_update_ic_delays + 0x14d (TSM_TDC)
0x11c31: TDC_ACCESSORIES_DELAY_BUDGET::perform_slack_allocation + 0xdc1 (TSM_TDC)
0x28abe: TDC_COMMON_ACCESSORIES::perform_slack_allocation + 0x4e (TSM_TDC)
0x2a79d9: _Dinkum_std::map<int,TDB_NODE *,_Dinkum_std::less<int>,MEM_STL_ALLOCATOR<_Dinkum_std::pair<int,TDB_NODE *> > >::~map<int,TDB_NODE *,_Dinkum_std::less<int>,MEM_STL_ALLOCATOR<_Dinkum_std::pair<int,TDB_NODE *> > > + 0x339 (fitter_vpr20kmain)
0x2a328c: _vpr_qi_timing_direct_api_get_delay_budget_data + 0x25c (fitter_vpr20kmain)
0x204fbd: _altera_timing_calculate_delay_budget_data + 0x19d (fitter_vpr20kmain)
0x1e9ab9: _aa_rt_perform_route_processing_after_first_iteration + 0x439 (fitter_vpr20kmain)
0x7d7c: mem_delete_helper + 0x9c (ccl_mem)
0x197589: _aa_route_alg_get_iteration_stats + 0x1d39 (fitter_vpr20kmain)
0x1968b4: _aa_route_alg_get_iteration_stats + 0x1064 (fitter_vpr20kmain)
0x195ca5: _aa_route_alg_get_iteration_stats + 0x455 (fitter_vpr20kmain)
0x1945a7: _aa_route_alg_perform_timing_driven_route + 0x47 (fitter_vpr20kmain)
0x1a7e8b: _aa_route_try_route + 0x11b (fitter_vpr20kmain)
0x13713c: _aa_flow_get_fit_attempt_string + 0xf1c (fitter_vpr20kmain)
0x136d21: _aa_flow_get_fit_attempt_string + 0xb01 (fitter_vpr20kmain)
0x135dda: _aa_flow_fit + 0xca (fitter_vpr20kmain)
0x8b8a9: _vpr_main_internal + 0x399 (fitter_vpr20kmain)
0x2672ae: VPR_QI_FACADE::vpr_qi_main + 0x12e (fitter_vpr20kmain)
0x2a552: _fitapi_run_vpr + 0x72 (fitter_fitapi)
0x3763d: FITCC_EXPERT::run_vpr + 0x11d (FITTER_FITCC)
0x388dc: FITCC_EXPERT::place_and_route + 0x13c (FITTER_FITCC)
0x39ae8: FITCC_EXPERT::invoke_fitter + 0x6a8 (FITTER_FITCC)
0x245a: _ftitan_execute + 0x22a (fitter_ftitan)
0x9940: fmain_start + 0x710 (FITTER_FMAIN)
0x741c: qfit_execute_fit + 0x19c (quartus_fit)
0x11a95: QFIT_FRAMEWORK::execute + 0x4b5 (quartus_fit)
0xd9e1: qexe_get_tcl_sub_option + 0x981 (comp_qexe)
0x10287: qexe_process_cmdline_arguments + 0x387 (comp_qexe)
0x10374: qexe_standard_main + 0x84 (comp_qexe)
0xb79e: qfit_main + 0x5e (quartus_fit)
0x1ce1: msg_main_thread + 0x11 (CCL_MSG)
0x1bc8: _thr_final_wrapper + 0x8 (ccl_thr)
0x1c55: msg_thread_wrapper + 0x85 (CCL_MSG)
0x6720: mem_thread_wrapper + 0x32 (ccl_mem)
0x2c423: msg_exe_main + 0x63 (CCL_MSG)
0xbc3c: _main + 0x1c (quartus_fit)
0x13afb: _memset + 0x15f (quartus_fit)
0x17076: RegisterWaitForInputIdle + 0x48 (kernel32)
End-trace
Quartus II Version 10.1 Build 153 11/29/2010 SJ Full Version
--- Quote Start ---
--- Quote End ---
Hi Briane,
I'm sorry that you're hitting this error - I'm part of the team that owns this code. Can you please submit an SR that includes a QAR of your design at https://www.altera.com/myaltera
Cheers, Adrian
Hi Adrian, thanks for the quick reply. It's SR# 10795756, and has a full 'service request w/ incremental database' qar attached so it will hopefully be easy for you to reproduce. Thanks & good luck. I'll keep my fingers crossed for a workaround. ;) -Brian
--- Quote Start ---
--- Quote End ---
Hi Brian, we couldn't reproduce this on a 64-bit Windows build. What OS and build (32 or 64 bit) were you using?
Hi, it's Windows XP Pro SP3 (32b), w/ an Intel X9770@3.2GHz w/ 4GB of RAM.
Also, note that this is compiled without a megacore ip license for the rapidio (in case that affects the generated IP timeout logic & affects your reproducibility).
