17255 Discussions
Internal Error: Sub-system: TDC, File: /quartus/tsm/tdc/tdc_accessories_analysis.cpp,
Hi All:
We are getting the following error when targeting a Cyclone III device:
Internal Error: Sub-system: TDC, File: /quartus/tsm/tdc/tdc_accessories_analysis.cpp, Line: 1571
m_edge_domain_data[iedge].m_relaxed_domain_slack_ratio < JUST_BELOW_HUGE_FLOAT
Stack Trace:
0x59E2 : _Dinkum_std::hash_compare<TDC_PATH_TIMING *,_Dinkum_std::less<TDC_PATH_TIMING *> >::operator() + 0x3B62 (TSM_TDC)
End-trace
Quartus II Version 7.2 Build 203 02/05/2008 SJ Full Version
Service Pack Installed: 2
Or
Internal Error: Sub-system: FITCC, File: /quartus/fitter/fitcc/fitcc_tdc_utility.cpp, Line: 1286
edge_slack_ratio >= 0.0
Stack Trace:
0x76027 : FITCC_TDC_UTILITY::get_slack_ratio_of_connection + 0x177 (FITTER_FITCC)
0x1324C8 : FSYN_EXPERT::tune_stability_threshold + 0x44F78 (fitter_fsyn)
End-trace
Quartus II Version 7.2 Build 175 11/20/2007 SJ Full Version
Service Pack Installed: 1
However the same code works under Stratix II and worked under Cyclone III until resently (minor code changes).
We have a service request in, but has anyone else seen these issues.. (As you can see we are on 7.2 either SP1 or SP2.
Pete
Try to close the project and delete the "db" subfold.
If it does it again could be an issue about the family and only the service request they can help you.
Hi Darkwave.. Thanks for the reply.
We tried deleting the db directory with no joy, but we have it working right now.
It seems to work with our "Dongle" license, but not the "Floating" license for quartus..
Very strange. Anyway, if we get a definitive answer from Altera to the cause, I'll post it.
