17255 Discussions
Internal fatal error when I try to compile and starting analys and synthesis
IESG2000
Hello.
I tried to compile simple programming in VHDL for comparison at inputs using logic gates.  When the compilation is working, pops up a window to inform me about an internal error, it happens when I try to do analysis & synthesis of the same programming, as well.
It started happening two days ago. Hence, the message of the window changes each time when I try to compile or do an analysis. Here's the last message that appeared to me:
*** Fatal Error: Access Violation at 0X00007FF4175CB220
Module: quartus.exe
Stack Trace:
0x45da63: QAccessible::queryAccessibleInterface + 0x33
0x46403c: QAccessible::setRootObject + 0x153c
0x4652e9: QAccessible::setRootObject + 0x27e9
0x9f06: CreateStdAccessibleProxyW + 0x4e6
0x338dd: UiaReturnRawElementProvider + 0x372d
0x7bcd6: UiaRegisterProviderCallback + 0x17446
0x73597: UiaRegisterProviderCallback + 0xed07
0x1fd37: DllCanUnloadNow + 0xde57
0x1cdcc: DllCanUnloadNow + 0xaeec
0x1ca2f: DllCanUnloadNow + 0xab4f
0x1c0e8: DllCanUnloadNow + 0xa208
0x3db14: UiaReturnRawElementProvider + 0xd964
0x3d7d6: UiaReturnRawElementProvider + 0xd626
0x1e021: Ordinal2712 + 0x191
0x20bc2: SendMessageTimeoutW + 0x142
0xa0b73: KiUserCallbackDispatcher + 0x23
0x1063: NtUserPeekMessage + 0x13
0xa5c2: PeekMessageW + 0x1e2
0xa522: PeekMessageW + 0x142
0x132d77: QEventDispatcherWin32::processEvents + 0x1c7
0x83564: QApplicationPrivate::translateTouchEvent + 0x884
0x109cf0: QEventLoop::exec + 0x230
0x420e3c: QDialog::exec + 0xec
0x643a7: AFCQ_MSG_DISPLAY::prompt_display + 0x2f7
0x10828: MSG_O::prompt + 0x8
0x266ea: QUI_FRAME_WND::flow_finish_prompt + 0x91a
0x461e8: QUI_FRAME_WND::qt_static_metacall + 0xa78
0x11d699: QObject::event + 0xd9
0x6ada8: QWidget::event + 0xd18
0x3989a4: QMainWindow::event + 0x284
0x228f5: QApplicationPrivate::notify_helper + 0xf5
0x25297: QApplication::notify + 0x17f7
0x10a7c1: QCoreApplication::notifyInternal + 0x71
0x10c7cb: QCoreApplicationPrivate::sendPostedEvents + 0x29b
0x1311de: QEventDispatcherWin32::event + 0x70e
0xe857: CallWindowProcW + 0x3f7
0xe298: DispatchMessageW + 0x258
0x132f69: QEventDispatcherWin32::processEvents + 0x3b9
0x10e5ff: QCoreApplication::exec + 0xdf
0x4c78: msg_exe_fini + 0x58
0x53bc: msg_exe_fini + 0x79c
0x1584: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0x5f9f: msg_exe_main + 0x8f
0x17033: BaseThreadInitThunk + 0x13
0x52650: RtlUserThreadStart + 0x20
End-trace
Quartus II 64-Bit Version 13.0.1 Build 232 06/12/2013 SJ Web Edition
Service Pack Installed: 1
I appreciate your time!
SyafieqS
Galvan,
Is this issue intermittently occur?
What device you are using? Can you migrate to the latest Quartus for supported device? as it has more bug fixed and updates.
Is reinstall the Quartus fix your issue?
Another way is to follow as what other user faced in below forum link
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Quartus-II-13-0-1-access-violation-error/td-p/1364514
IESG2000
Hello.
I reinstalled Quartus II 3 times; it again popped up with fatal errors. I used an old FPGA; Altera DE2 board Cyclone II EP2C35F672C6; i.e. the reason I use Quartus II v13 is that it is the oldest version of the software available to download from the intel website, and it can support the mentioned board. Hence, I gonna see the direction suggested by you.
I appreciate your attention. Blessings!
IESG2000
I saw the problem that you suggested to me, I did it and it works. Thanks so much.
SyafieqS
Galvan,
Glad you able to resolve it.
May I know if you able to share the qar design file or zip files for me to reproduce the issue.
This issue will be filed as KDB.
Appreciate you effort, thanks
SyafieqS
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
