17253 Discussions
Is DDR5 phy-only IP available?
nama828
Hi!
I'm using Agilex 7 M-series (AGMF039) and Quartus Prime Pro 24.2.
I'm looking for DDR5 PHY-only IP, but I couldn't find it in the EMIF IP.
However, I confirmed that PHY-only mode is provided for DDR4 in Agilex 7 I/F-series.
So, I have two questions:
1. Is there a plan to release DDR5 PHY-only IP? If so, could you provide a rough release date?
2. If I modify the EMIF_DDR5 IP to use it in PHY-Only mode (e.g., emif_ph2_620), can it be synthesized and ported to the FPGA?
Thank you.
AdzimZM_Intel
Hi nama828,
"1. Is there a plan to release DDR5 PHY-only IP? If so, could you provide a rough release date?"
  • Yes, there is plan to support PHY-only mode in EMIF IP for Agilex 7 M series device but the release date is not yet confirmed.
"2. If I modify the EMIF_DDR5 IP to use it in PHY-Only mode (e.g., emif_ph2_620), can it be synthesized and ported to the FPGA?"
  • No, because the EMIF IP is using harden circuitry.
Adzim
AdzimZM_Intel
Hi nama828,
Adzim
