17238 Diskussionen
Is there a specific driver for the USB Blaster III?
zener
Neuer Beitragender I
943Aufrufe
Is there a specific Linux driver or firmware which is required for the USB Blaster III (ArrowAXE5000)?
It does not get detected when I run  jtagconfig?
# dmesg |grep 'USB Blaster III' -A1
[9415753.839630] usb 1-4.4: Product: USB Blaster III
[9415753.839635] usb 1-4.4: Manufacturer: Altera
# jtagconfig --version
jtagconfig
Version 25.1.0 Build 129 03/26/2025 SC Pro Edition
Copyright (C) 2025 Altera Corporation. All rights reserved.
# jtagconfig --enum
No JTAG hardware available
Does it require some specific firmware and software to load it?
Beschriftungen (1)
4 Antworten
zener
925Aufrufe
It appears that after I started quartus_pgmw I was able to detect it, even in jtagconfig.
Fakhrul
Mitarbeiter
314Aufrufe
Hi Zener,
I have attached the instructions. They are currently only available on request and not available on-line.
Fakhrul
PrivateIsland
Einsteiger
275Aufrufe
Please let me know the plans to support Onboard USB III in Quartus Standard and Lite.
FvM
Geehrter Beitragender II
261Aufrufe
presently, existing development boards with onboard UB3 require Quartus Pro, e.g. said Agilex 5 board AXE5000. They are supported by Quartus 25.1 Pro. Expect that upcomming Quartus 25.1 Std will contain same UB3 driver. For the time being, you can install Quartus 25.1 Pro standalone programmer and use its jtagserver with your Quartus lite or std Version to enable UB3 support, e.g. to support homemade FT4232 programmer solutions.
Frank
Antworten
