17256 Discussions
Is there any way of changing the background of the ModelSim output waveform. By default it is black and I wanted to change it to white. If there is please let me know.
RPada2
RichardTanSY_Altera
Basically, you need to start up Modelsim: 1. Select on Menu: Tools > Edit Preferences. This will open up a "Preferences" dialog box. 2. In the dialog box, Select "Wave Windows" from "Window List" on the left-hand side. This will change the right-hand side of the dialog box to the "Wave Window Color Scheme" Listbox. 3. Select "waveBackground" from the ListBox. Select White color from the color palette. 4. Click Applied and your waveform background will change to white. Should you change the background to white, the text will not be visible as they are white by default. Feel free to explore the other features in the ListBox for a better experience. Hope it helps.
