17253 Discussions
Issue in Quartus 16.1 with Windows 11 Pro
PiyushM
IssueIssueHi,
I am using Quartus Prime 16.1 Standard Edition and utilize schematic entry to create .bdf file.
OS is Windows 11 Pro.
I am facing issue to view
1) Block & Symbol names
2) Instance, bus, node & conduit names
3) Port name aliases
4) Comment & other text
Check the Image. Text is cut from the end.
In the image, a node CLK1_25E is not visible completely. “_” and “E” are missing in the view. They are completely visible when open Node Properties.
I am trying by changing different Font Type, Size and Style in the Quartus Font setting but still the result is same. Also change the screen resolution but still the result is same.
Please help to resolve the problem.
ShengN_Intel
As mentioned, version 16.1 is not supported in Window 11.
Sheng
sstrell
It's almost a 10 year old version of the software.  It is not supported in Windows 11.  As such, there's no guarantee that anything will work correctly.  You should use a more recent version of Quartus.
PiyushM
Hi sstrell,
Thanks for reply.
I am checking the same file to open in Quartus II 9.1 sp2, it is still okay when open in Windows 11 pro.
FvM
It's apparently a problem with text scaling, I'm not even sure if it's directly related to Windows 11 versus Windows 10. There are probably ways to tune text display, e.g. changing resolution or text size in Windows.
But as stated, there's no guaranteed Windows 11 support for old Quartus Versions. I'd not specifically worry about V16.1, rather about V9.0, V13.0 and V13.1 that are required to maintain legacy device and e.g. Cyclone to Cyclone III designs. Fortunately they basically work under Windows 11, although not even Windows 10 is officially supported. If you rely on specific functionality of a certain version that doesn't work under Windows 11, you should consider a virtual machine.
PiyushM
Hi FvM,
Thanks for reply.
There is no issue with Window 10 OS, when working in Quartus 16.1, 13 or 9.1.
For solving the text scaling issue with Windows 11, I already tried with the option of changing screen resolution, change text setting in Quartus 16.1.
I am still trying to get the solution with Windows 11, meanwhile Virtual Machine is the good solution.
ShengN_Intel
Sheng
PiyushM
Hi ShengN,
Thanks for reply.
We will downgrade OS to Window 10. It is the Final Solution.
PiyushM
I changed the Display scaling to custom value 110% and all display related problem is solved.
