17265 Discussions
Issue when converting between multiple data types
Hello everybody I have an issue with this one line of code here:
output(to_integer(unsigned(msbd) + unsigned(lsb)) downto 0) <= bit_field(to_integer(unsigned(msbd) + unsigned(lsb)) downto to_integer(lsb));
bit_field and output are 32 bit std_logic_vector
msbd and lsb are 5 bit std_logic_vectors
Issue is when I convert the VHDL file to a symbol file I get this:
Error (10405): VHDL error at aluvhdl_entities.vhd(896): can't determine type of object at or near identifier "to_integer" -- found 0 possible types
Can some one tell me what the issue is?
use ieee.numeric_std.all;
Im assuming lsb is a std_logic_vector? you forgot to cast it to an unsigned at the end of the line before using the to_integer conversion.
PS. I dont think you'll get the circuit to synthesise if msbd and lsb are signals.
--- Quote Start ---
--- Quote End ---
The thing is that I am using IEEE.NUMERIC_STD.ALL
EDIT: I casted the std_logic_vector to unsigned and then integer. It created a bsf but now I will test synthesis
EDIT2: I got this error during synthesis
Error (10779): VHDL error at ALUVHDL_entities.vhd(896): expression is not constant
as I suggested - you cannot do this if msbd or lsb are signals and not constants.
--- Quote Start ---
--- Quote End ---
Is there any way how to circumvent that without resorting to a different design?
Yes - you'll need to use a for loop to check to see if each individual bit should be assigned,.
Then will I just need to use one for loop or will I possibly require more?
one should do it.
--- Quote Start ---
--- Quote End ---
Basically you are trying to do this: LHS(msb + lsb downto 0) <= RHS(msb + lsb downto lsb) ; which doesn't work as the LHS is wider than the RHS.
Using for-loop won't work either as a for-loop needs constant boundaries as well.
You could use a barrel shifter to dynamically align data.
--- Quote Start ---
--- Quote End ---
Could it work if I pad the zeros in the beginning and the end?
EDIT: I figured out that having two shifters will do it.
It is not clear to me what you are trying to achieve, but padding the RHS either end (adding zeros at the top or bottom or both) will pass.
--- Quote Start ---
--- Quote End ---
I did mess up my explanation there. Sorry about that.
I have a similar issue right now with this:
left_shift_amount <= 32 - unsigned(msbd) - unsigned(lsb); right_shift_amount <= left_shift_amount + unsigned(lsb); output <= std_logic_vector(Shift_right(Shift_left(unsigned(bit_field), left_shift_amount), right_shift_amount));
It says that left_shift_amount and right_shift_amount do not agree as being natural types.
--- Quote Start ---
--- Quote End ---
It would work if you loop through the whole of the output and see if the current bit should be assigned a specific bit from the bit_field.
--- Quote Start ---
--- Quote End ---
Agree. Worth trying once and see what the RTL looks like.
--- Quote Start ---
--- Quote End ---
I believe it unrolls the loop. I will try it now
Edit:
I have this so far but I get an error that bit_location is not a natural type:
output <= (others => '0'); for i in 0 to 31 loop bit_location <= i - unsigned(lsb); if (i >= unsigned(lsb)) AND (i <= unsigned(msbd)) then output(bit_location) <= bit_field(i); end if; end loop;
Edit2:
I also tried this but its the same error:
for i in 0 to 31 loop bit_location <= i + unsigned(lsb); if (bit_location >= unsigned(lsb)) AND (bit_location <= unsigned(msbd)) then output(i) <= bit_field(bit_location); end if; end loop;
i is an integer. unsigned(lsb) is an unsigned. You need to convert lsb to an integer:
to_integer( unsigned( lsb) )
I would also make bit_location a variable, otherwise it is always going to be set to 31 + Lsb as signals are only updated when a process halts.
Ok it compiled this:
and I got this:
https://www.alteraforum.com/forum/attachment.php?attachmentid=6527
It looks like it is not done properly
It isn't. As Tricky says you have to declare bit_location as a variable, local to the process: process( bit_field , msbd , lsb ) variable bit_location : natural ; begin output <= (others => '0') ; for i in 0 to 31 loop bit_location := i + to_integer( unsigned(lsb) ); if (bit_location >= unsigned(lsb)) AND (bit_location <= unsigned(msbd)) then output(i) <= bit_field(bit_location); end if; end loop; end process ;
The RTL now is a lot bigger, but also very difficult to understand, if at all :)
It uses 308 LCs.
A solution using one or more barrel shifters will be smaller.
Ok so it works, now I am working on a similar piece which is more complicated. I once again tried doing it a simpler method but it didn't work. My guess is that I will need some really elaborate for loop combination to do this one.
insert_value_index := to_integer(unsigned(msbd) - unsigned(lsb)); insert_value := to_integer(unsigned(source_register(insert_value_index downto 0))); destination_register_upper := to_integer(unsigned(destination_register(31 downto 1 + to_integer(unsigned(msbd))))); destination_register_lower := to_integer(unsigned(destination_register( to_integer(unsigned(lsb)) - 1 downto 0))); output <= std_logic_vector(to_unsigned(destination_register_upper, 31 - to_integer(unsigned(msbd)))) & std_logic_vector(to_unsigned(insert_value, insert_value_index)) & std_logic_vector(to_unsigned(destination_register_lower, to_integer(unsigned(lsb)))) ;
