17255 Discussions
Issue with TSE ip after quartus prime upgrade 22.4.0 build 94
Antonino88x
I have updated Quartus from version 20.2 pro to the new 22.4.0 build 94.
After manually updating all ip components, I see an issue on my design using tse version 21.0.0. These are the ip configurations:
Core variation: 10/100/1000Mb Eth MAC with 1000BASE-X/SGMII PCS
Internal fifo : enabled (2048 x 8bits both  rx and tx)
Number of ports: 1
Transceiver type :GXB
Mac option: only include statistics counters.
Device : Cyclone 10GX.
The issue seems on rx part of the mac. Analyzing internal signals with signal taps with rx_clk (internal clock), on gmii_rx_d bus I see on every rx packet that the preamble duration can change from 6 to 7 clock cycles. Every time the mac module receives a preamble with 6 clock duration it discards the packet (ff_rx_dsav is 0 and never rise).
Trying the same design with quartus  pro 20.2 and tse ip version 19.4.0, I see the same preamble variation but the mac ip always detects all rx packets as corrects.
These are my register configurations:
pcs status: 0x0000008D
pcs control:0x00000160
pcs if_mode:0x00000008
mac cmd config:0x0100013B
Can you please help me or have you already encountered a similar issue?
Thank you,
Antonino
ZiYing_Intel
Thanks for submitting the issue.
Can share the .qar file? So that I can try debug the issue from my side.
Zi Ying
ZiYing_Intel
For further information about preamble, please do refer link below, https://www.intel.com/content/www/us/en/support/programmable/articles/000083600.html
Zi Ying
Antonino88x
Hi Zi Ying,
sorry if I reply late but I can't share my project (forbidden by our company).
From your link is clear than the receiver pcs may generates preamble with 6 octets.
My question is why in this case the new version of mac ip discards the received packet?
