Hi, i'm facing with issues relative to blinking_led partial reconfiguration example .sof recording. When i'm trying to program .rfb file, Programmer reports a error relative to access TIMEOUT and also, reports that PR_ERROR flag goes to high, signal from Partial reconfiguration controller IP, i think.
Someone already faced with the same issue? Dip switches positions should stay in default configuration?
I'm using the Arria 10 GX Development kit.
Are you using internal host or external host? How do you send your data to the PR IP?
May I know how do you implement your design using internal host? Is your data is being sent to the PR IP correct?
You can refer to https://fpgawiki.intel.com/wiki/Partial_Reconfiguration_Example_Design_with_Avalon_MM as your example
The design is similar to the JTAG Master. You just need to change the connection for the design from JTAG Master to PCIe. Then you can directly control the PR IP through PCIe. You may follow the System Console TCL on how to send the data to the PR IP by converting the code to PCIe driver.
