17255 Discussions
Issues with output of register values
I am trying to create a chip that takes 512 bit data through the data bus, process that and produces a 512 bit data.
I am having issues with outputting the processed data through the output pins. For now, Roughly system consists of two verilog files which are say process.v and testbench.v
Issue is that whenever I try to output the processed data[saved in reg variables] the Altera Quartus gets stuck on the compilation process[no errors]. The process file consists of the following format
module Process(input clk, input startInput, input getResult, input [31:0] ip1,input [31:0] ip2,output reg [31:0] op1)
reg [31:0] input1 [15:0],
reg [31 : 0] input2 [15:0],
reg [31 to 0] temp [15:0]
always at (posedge clk) begin
initialize and read ip1, ip2 value from testbench on startInput and store to input1 and input2
process: temp = input1[] + input2[]//loop
output op1[] = temp[] // step 3, loop
end
Now, system takes forever to finish the compilation process when I add step3. If I say op1[0] = 32'h0, compilation process goes smoothly. Not sure why that would be the case. I would like the data to be read by a databus from the output pins.
Sorry for the long question..Im lost and any suggestions would be helpful.
why not post the real code?
Its too large to be posted;)..I believe there are some non-synthesizable components in the code..Im trying to change them..will get back if required. Thanks for your response.
You say, you are compiling a testbench, that reads data in a loop in Quartus. This most likely won't work.
Quartus can compile synthesizable designs, testbenches have to be processed in ModelSim.
