17267 Discussions
Iteration limit 5000 reached at time X ns.
akhal10
I'm an absolute beginner to this world, i've made a schematic for my design then compiled it (which done successfully) then run the simulation first i hadn't set any input to high and everything worked fine but when i set whatever input to high (except the clock for sure) i got "Iteration limit 5000 reached at time X ns." error, where "X" is the time i set the input pin to high. so what's the problem and how to fix it?
environment:
  • Quartus prime lite 18.1 Linux version
Vicky1
Hi Abdullah, This issue may occur because of delay.. Could you please provide the schematic & corresponding HDL code for the design used? Regards, Vikas
