Hi
I have one probleme with my usb blaster on CentOS 5.5. Unable to lock chain (Insufficient port permissions). I have found a topic on this on the forum but from 2007 and I want to know if the procedure here is up to date yet. http://www.alteraforum.com/forum/showthread.php?t=1207&highlight=usb+blaster And the nioswiki (at http://www.nioswiki.com/operatingsystems/uclinux/quartusforlinux) do not say the same procedure which is for ubuntu and Suse (as written in the "setup JTAG" section) Can you help me ?Link Copied
Please kill jtagd process. And run it as root.
mkdir /etc/jtagd cp /opt/altera9.1sp1/quartus/linux/pgm_parts.txt /etc/jtagd/jtagd.pgm_parts Add these lines to /etc/rc.local to start jtagd server. As root or via sudo. /opt/altera9.1sp1/quartus/bin/jtagd- Mark as New
Thank you. It works.
