Kernel Vectorization
hi
void tempA( ...) {...};
void tempB( ...) {...};
void processing(global int *a){
if(a == 0)
tempA( a );
else
tempB( a );
__attribute__((num_simd_work_items(2)))
__attribute__((reqd_work_group_size(256,1,1)))
kernel void test (__global int * a ) // NDR , globalsize = a /2 , initial a[ 0~N ] = 1
int gid = get_gloabla_gid(0);
for(int i = 0 ; i < 2 ; i++){
while(a[gid + i] == 0)
processing(&a[gid + i]);
The code I wrote above is the thing I was trying .
It showed that "Compiler Warning: Kernel Vectorization: branching is thread ID dependent ... cannot vectorize."
How to solve or explain this situation ?
And while loop with unpredicted end condition is not friendly for vectorization and very inefficent , right ?
It means that one of your branches is thread ID dependent. So the follow section
while(a == 0) processing(&a);
is thread-id dependent. Best practices guide states to avoid work-item dependent backwards branching.
Thanks okebz ,
So , if my write as follows , is it the same things ?
void processing(global int *a , int *b){
if(a == 0)
tempA( a ,b);
else
tempB( a ,b);
int b ;
while ( b ==0 )
processing(&a[gid] , &b );
But if my program flow is as previously said , how to optimize this code ?
Each workitem stays in while loop until condition is matched.
Is it better to use task instead of NDR ?
Regards .,
As long as b is not dependent on the work-item ID. Yes, depending on what you're trying to do, it seems like a single task would be better. If your problem data set cannot be divided into independent sections and depends on other work items, then a single work-item kernel might be a good choice.
