Kernel mode Driver
名誉分销商 II
5,789 次查看
Hi to all,
I am facing Problem regarding the quartus programmer. when i going to add hardware it doesnot show "lpt1" instead of that it is showing "kernel mode driver is not installed".
i have purchased the new PC which does not have parallel port installed in it, thus i have added a pci based parallel port card and installed the respected driver for it.
kindly help me to get rid of this situation
Warm Regards
Preet
0 项奖励
10 回复数
名誉分销商 II
2,980 次查看
I have excactly the same, no solution found yet...
Stefaan
0 项奖励
名誉分销商 II
2,980 次查看
Same here too.
Markus
0 项奖励
名誉分销商 II
2,980 次查看
Me too face same problem. Please suggest some solution.
Job Joseph
0 项奖励
名誉分销商 II
2,980 次查看
Hello, everybody.
I have the same problem.
As well as Preet i am using a PCI-based Parallel Port Card. I was able to connect a parallel printer to it (LPT1) and i was also able print with it.
So principially the parallel port is working fine.
In my mind the installation of the "Altera Byte Blaster" driver may be the basic problem. I followed the installation instructions on
http://www.altera.com/support/software/drivers/dri-index.html?gsa_pos=1&wt.oss_r=1&wt.oss=programming%20cable%20driver
but this didn't change something.
If anybody has an solution for the problem, i would really appreciate it.
Marc
0 项奖励
名誉分销商 II
2,980 次查看
Hi
Has anyone found a solution to this problem?
I have encountered the same problem
Anyone has VMware intsalled on the machine?
0 项奖励
名誉分销商 II
2,980 次查看
Hello.
Can you check, if the following services are running?
parport.sys
parvdm.sys
To do so, just type the following in the command line:
sc query parport
sc queryc parvdm
If both services are running, you can try the following:
Goto .....\program files\Altera\80\quartus\drivers\i386
and execute bblpt.exe with the option /i
This should install the driver.
Thats just the answer, I got from the support. In my case it did not solve the problem. If one of the services fail, you have a problem that is not related to Altera software, i think.
Kind regards,
Marc
0 项奖励
名誉分销商 II
2,980 次查看
Hi There
thank you for the repsonse
I found one service not running
C:\altera\72sp3\quartus\bin>sc query parvdm
SERVICE_NAME: parvdm
TYPE : 1 KERNEL_DRIVER
STATE : 1 STOPPED
(NOT_STOPPABLE,NOT_PAUSABLE,IGNORES_SHUTDOWN)
WIN32_EXIT_CODE : 20 (0x14)
SERVICE_EXIT_CODE : 0 (0x0)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
0 项奖励
名誉分销商 II
2,980 次查看
--- Quote Start ---
--- Quote End ---
I had problems installing ByteBlaster on my VMWare machine. Though I used Linux on my host as well as VMware machine, I was able to resolve the issue. I have reported my complete problem and solution here:
http://www.alteraforum.com/forum/showthread.php?t=3052
0 项奖励
名誉分销商 II
2,980 次查看
Good day readers
I have managed to get my ByteBlaster working
My LTP1 is native
In Device manager it showed 2 x paralel ports
LPT1 - ECP printer port
LPT3 - Unusable Port
I uninstalled LPT3
i Then did update driver on LPT1 and chose ECP printer port
in command line
sc start parvdm.sys
and bblpt.exe
restart computer
installed byteblster driver as per altera recommendation
reboot
and presto Bob's your Aunty
0 项奖励
名誉分销商 II
2,980 次查看
Hello guys,
I found thread with very good instructions, it helped me a lot :)
this damn system cant allow me post link, because I am newbie. So, google term "Configuring ByteBlaster and putting Kernal Mode driver to bed"
It is very good thread on alteraforum
0 项奖励
回复
