LCD Procedure code
I need a procedure to write a word in the lcd that I can call any time, so i thought of something like this:
procedure write1 is
variable cont1: integer range 0 to 18;
begin
for cont1 in 0 to 18 loop
case cont1 is
when 0 =>lcd_rs<='0';
lcd_data<=x"C0";
when 1 =>lcd_e<='1';
when 2 =>lcd_e<='0';
when 3 =>lcd_rs<='1';
when 4 =>lcd_data<=x"4C"; --L
when 5 =>lcd_e<='1';
when 6 =>lcd_e<='0';
when 7 =>lcd_data <=x"49"; --I
when 8 =>lcd_e<='1';
when 9 =>lcd_e<='0';
when 10 =>lcd_data <=x"4B"; --K
when 11 =>lcd_e<='1';
when 12 =>lcd_e<='0';
when 13 =>lcd_data <=x"45"; --E
when 14 =>lcd_e<='1';
when 15 =>lcd_e<='0';
when 16 =>lcd_rs<='0';
lcd_data<=x"80";
when 17 =>lcd_e<='1';
when 18 =>lcd_e<='0';
lcd_rs<='1';
end case;
end loop;
end write1;
I want to use it like this in a fsm:
if(w1='1' and w2= '0' and w3 = '0') then
write1;
elsif(w1='0' and w2 = '1' and w3 = '0') then
write2;
elsif(w1='0' and w2 = '0' and w3 = '1') then
write3;
elsif(w1 = '0' and w2 = '0' and w3 = '0') then
clearline2;
end if;
But it seems i got all wrong, can someone explain what i should do?
You're using vhdl like c. A sequential circuit with no clock. Mmmm....
What I do: I'll write a simple module that control the timing of the lcd_enable signal. You fire it with a start input and this acknowledges with an end_tick signal when it finishes. Then I'll instantiate this module inside a state machine that sends the comands and ascii to lcd.
